G550 Front Seat Tilts to 1 side when Moving Back
Old May 3, 2017 | 06:58 PM
TuLsaViPeR's Avatar
C230, G550
My G550 Seat Tilts when moving to One side... I took it to the dealer he said something was not connected. He charged me $95 to fix it... 1 Day later it does the same thing again.
Call the dealer again, and a different tech tells me that the seat track is bent, and it will cost $2900 to replace the entire seat motor and frame. I said Fuch Off!!!
called back ttracked down the original tech who fixed it and he fixed it again, this time for free.
Has anyone here experienced this same problem, and HOW DO I FIX THIS PROBLEM FOR GOOD?
Old May 3, 2017 | 07:00 PM
TuLsaViPeR's Avatar
C230, G550
By the way this is a 2013 G550-W4. Ive had it for 1 month. CPO Good for 1 year.
Old May 3, 2017 | 07:09 PM
ItalianJoe1's Avatar
2003 CL 600
The drive motor for the seat has a cable on either side, one of them has come off.
Usually, there is something pushed under the seat that damages them when moving the seat, and it can bend the mountings for the motor or break the cables/drives.
If they were able to "reconnect" it, I'd suspect you have something bent. If the specific part isn't available separately, you may need to buy the entire seat frame to get it. I had to replace an entire seat frame on a brand new S65 for that reason, customer had a roll of duct tape under the seat and all other kinds of junk, something jammed in the mechanism and the seat would only go front-back about 3 inches. No serviceable parts, sells only as the entire frame, called the "seat adjustment mechanism".
At that point, if you have no warranty coverage, try to find an independent mechanic willing to open it up and repair/replace what he can to make it work properly.
Old May 3, 2017 | 09:03 PM
TuLsaViPeR's Avatar
C230, G550
Well I just did a simple google search and i found the part online for $50 not $2,900.
https://www.megaparts.eu/en/product/1146424869
Old May 3, 2017 | 10:11 PM
2003 CL 600
That's just a used motor for an old 140... not the same as your truck at all.
While I don't doubt that you can replace the motor, it's entirely possible that MB does not sell it alone, as I have seen this on the 222/217 recently.
Old May 3, 2017 | 10:14 PM
2003 CL 600
You couldn't get it covered under CPO warranty?
Old May 4, 2017 | 02:04 PM
TuLsaViPeR's Avatar
C230, G550
HELL NO!! SO FAR, THAT CPO IS PROVING TO BE GARBAGE! ITs Just Marketing. Its a ploy to get us to buy their stuff, and then claim that nothing is covered except of thte transmission and the engine.
Old May 4, 2017 | 07:47 PM
2003 CL 600
Well, base CPO has it's limits, yes. If I were you, i'd look into purchasing an MB extended warranty, before your CPO runs out. It's much more inclusive than most CPO plans.
Old May 23, 2017 | 12:32 AM
TuLsaViPeR's Avatar
C230, G550
UHHH No! Thanks for the reccomendation. I had an extended warranty on my sprinter which was totaled, and I still havnt received my refund on the unused warranty.
I bought another sprinter and the Service guy told me that if im in a accident that they can void the warranty. My current sprinter was in an accident and the AC doesnt work and since the sprinter was in an acciden they dont want to fix it.
So No! Im done with extended warranty's.
