2019 G 63 Rear Window cracked
Old Feb 24, 2019 | 01:58 PM
WoodlandsGuy's Avatar
2014 GL450, 2019 G63 Edition 1
Have has my G63 Edition 1 about 2 weeks and today noticed that the rear passenger window is cracked from top to bottom. No signs of distress or outside damage. It just cracked all the way up. Has anyone else experienced this?
Old Feb 24, 2019 | 02:25 PM
lou1947's Avatar
[QUOTE=WoodlandsGuy;7689802]Have has my G63 Edition 1 about 2 weeks and today noticed that the rear passenger window is cracked from top to bottom. No signs of distress or outside damage. It just cracked all the way up. Has anyone else experienced this?
[/QUOTEWondering what is going on with all the cracked windows on the new G Wagons. For a vehicle that is supposed to be stiffer than the old model we shouldn’t be seeing all these cracked windows. Could it be poor window fitting at the factory or defective glass manufacturing?
Old Feb 24, 2019 | 03:31 PM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
from a forum perspective, this is the first rear window crack. Many have had front windshields crack however. Keep us posted will ya?
Old Feb 24, 2019 | 07:36 PM
Snipe10's Avatar
2026 Porsche Macan GTS , 2026 Chevy HD2500 Silverado
Hope there's not a glass problem as they're not cheap! I'm making sure I get the best coverage I can on glass.
Old Feb 25, 2019 | 01:43 AM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
hmm..appears to be a theme with the cracked glass, first front windshields and now rear window.
Has there been temp difference exposure etc for long period of time? i.e., heating inside and driving/parked out in the snow for a long time? Regardless, that shouldn't cause the windows to be cracking. This is a bit concerning...
Old Feb 25, 2019 | 04:20 PM
Sarlox's Avatar
2014 ML63 2015 G550 2016 G550 & (2) 2019 G550s
Wow, that's the first time I have seen a rear window crack.
Old Feb 25, 2019 | 04:52 PM
I only received 2 weeks ago. Prior was sitting at Brunswick, GA since mid-late December. I live in Houston so in February we don’t normally get extreme temperature changes like you guys up north. Summer time. Different story. Took it to dealer this morning and they are working to try and find a replacement window. Will keep you posted if this is classified as a warranty item or not. While it’s a pain. I understand that’s the risk I take every time I order the brand new model of anything. Which is what I do typically with most of my purchases. Early adopter frustrations. First world problems.
Old Feb 26, 2019 | 08:04 PM
Wassaby's Avatar
2018 E400W4 EU Delivery 1999 E320 2022 E53 COUPE
That should be 100% warranty.
Old Feb 27, 2019 | 12:44 PM
Snipe10's Avatar
If not warranty, please let us (me) know! Bad sign even though from a small sample.
Old Jul 26, 2023 | 06:03 PM
1972arg's Avatar
G63
Hi
today I went thru the same situation on my 2022 G63
ibwas wondering if the dealer covered the glass and labor under the warranty
Old Jul 26, 2023 | 07:44 PM
Originally Posted by 1972arg
Hi
yes. It was covered under warranty. I still have my 2019 Edition 1 and still love it as much as I did when I got it in 2019. Hope you’re enjoying yours as well.
Old Jul 26, 2023 | 09:15 PM
1972arg's Avatar
G63
Thanks so much for your quick response
Hopefully they will honor the warranty
Old Jul 26, 2023 | 11:23 PM
Ive found out earlier that a probably small rock hit my glass and caused the split. Hopefully they will honor the warranty
I had no physical damage of a rock or impact that would have caused my glass to crack. The dealership agreed that it had to be a manufacturing defect with the glass. Either way dealer was cool about it and replaced under warranty. Good luck.
