Is this a shipping bracket? 2018 G63
Old May 12, 2019 | 01:40 AM
edster's Avatar
2018 AMG G63
It looks like this is a shipping bracket that the dealer forgot to remove. It's bolted to the driver side tow hook, and sticks out quite a bit past the skid plate. It seems like if I bottomed out on the skid plate it would dig in or bend. I tried to remove it but I need to remove the skid plate to get it off. Might have been why it wasn't removed in the first place. It's on a 2018 G63. Thanks in advance!
Old May 12, 2019 | 08:03 AM
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Looks like the dealer missed that tie down hook. Next time its in for service ask if they will remove it. Depending on your relationship with the dealership they may not even charge you...especially if you purchased the vehicle from them. I don't see where leaving attached would cause any damage. That mounting point is pretty high up in the chassis. Good luck.
Old May 12, 2019 | 03:39 PM
rudys_500's Avatar
2002 G500 thulit red
my guess is its a hook you need when pulling a Toyota
Old May 12, 2019 | 05:06 PM
places's Avatar
No more MB:(
I still have mine, whatever it is.
Old May 12, 2019 | 07:22 PM
Mopars's Avatar
2018 G63
Me too
Old Jul 7, 2019 | 05:09 PM
mrtonyn's Avatar
1999 E320, 2008 S550, 2016 G63 AMG
Now that I look at it closely, it does seems to stick down too low and looks out of place.
The other one on opposite side is not very noticeable unless you bend down and look for it.
Can anyone confirm if it was designed for transporting the vehicle only and can be safely removed if desired ?
Old Jul 7, 2019 | 08:04 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
I don’t believe it is a shipping bracket. My G63’s has one too and after a closer look it looks like it is intentionally that long so when you use it the tow line won’t hit your bumper.
Old Jul 7, 2019 | 11:01 PM
mrtonyn's Avatar
Makes sense about it being lower so tow strap will not hit bumper.
Why is the hook on the other side not as low? Maybe that is the transporting/shipping bracket??
Old Jul 9, 2019 | 08:41 AM
edster's Avatar
2018 AMG G63
I'm pretty sure it's a shipping bracket. It's not coming off without removing the skid plate though. The part looks like it's a quality part but with a cheap paint job, it's already rusty. Plus it hangs down so far if I did hit anything it would get damaged or damage the tow hook that its bolted too. The tow hook on the other side is protected by the skid plate.
Old Jul 9, 2019 | 11:16 AM
places's Avatar
No more MB:(
I believe it's called a towing eye. Looked it up in the owners manual.
Old Jul 9, 2019 | 11:51 AM
mrtonyn's Avatar
I was thinking the same, if I run over or hit something that hook is going to be damage first since it is hanging low.
