Headlights swap
Old Sep 13, 2019 | 04:49 PM
simandang's Avatar
G63/RR LWB/W222 S550
I think i have decided to go with these.
I hope the LEDS last I remember 3 years ago on my at the time new 2016 Highlander they released these cool LED style taillights and within a few months they were destroyed by LEDs that burnt out.
Old Sep 15, 2019 | 07:51 PM
obz's Avatar
obz
Mercedes-Benz W463
Originally Posted by simandang
I was just about purchased the mansory style headlights for my 14 G63 but these look really sick. I think these LED are much brighter than the mansory style so now I am confused on what to do ??
I would love to wire them to the turn signals anyone do that yet
Honestly, super easy to do. Single wire that goes to the "hot" wire on your turn signals. Just splice it in.
Old Sep 16, 2019 | 03:45 PM
simandang's Avatar
Doesnt seem to bad.
Just ordered these along with a bunch of other goodies. Cant wait till everything comes in !
How long did the overall install take
Old Sep 16, 2019 | 03:50 PM
horse86's Avatar
Range Rover, M5
Doesnt seem to bad.
well what else did you get!?
Old Sep 16, 2019 | 03:55 PM
horse86's Avatar
Range Rover, M5
do these do the rotary sequential dance on startup like the video in the ad? Does turn signal also do a rotary flash or does the whole ring flash?
Old Sep 16, 2019 | 08:46 PM
simandang's Avatar
I bought brabus lip and smoked brabus leds for the bottom, led turn signals, black gloss grill guard, black gloss grill, black badges, 31mm spacers, carbon fiber goodies and I am looking for some all terrain tires for the stock 20s.
Old Sep 16, 2019 | 10:12 PM
  #32
horse86's Avatar
Range Rover, M5
^^ very nice list. PM sent
Old Sep 18, 2019 | 06:56 PM
  #33
obz's Avatar
obz
Mercedes-Benz W463
Doesnt seem to bad.
Depends on what you do honestly. If you're just going to put them in by themselves, not long at all. I added HID's so way longer just to get everything mounted up and looking nice behind the wheel well.
Old Sep 18, 2019 | 07:13 PM
  #34
simandang's Avatar
Does the grill guard need to come off to install these ? I have the black one on order.
Funny how the headlights from china came in 2 days literally but all the parts from the USA taking 10 days+
Old Sep 19, 2019 | 10:53 AM
  #35
obz's Avatar
obz
Mercedes-Benz W463
Grill does need to come off, yes. Pretty easy to pull though.
Old Sep 19, 2019 | 12:32 PM
  #36
simandang's Avatar
the grill i know but what about the brush guard grill the metal guard over the grill I would think so
is there a guide you guys followed
Old Sep 19, 2019 | 05:06 PM
  #37
obz's Avatar
obz
Mercedes-Benz W463
No, brush guard can stay on. Doesn't need to come off. Pretty easy to do actually. Listed out the steps below:
Below each headlight surround are 2 phillips screws - unscrew
Lift up on the headlight surround but don't fully remove
Behind the surround are the washer hoses for the headlight washers
Using a phillips screw driver loosen the clamps and wiggle the hoses off the washer nipple
Remove the headlight surround
3 phillips screws hold on the headlight to the body - remove all 3 screws
The headlight assembly can now be removed.
Youtube video below as well:
Old Sep 19, 2019 | 05:39 PM
  #38
simandang's Avatar
Wow that is easy I might tackle it tonight.
It is too easy I think IMO anyone can steal these lights off when parked. I street park often hmmm
Old Sep 20, 2019 | 10:09 AM
  #39
horse86's Avatar
Range Rover, M5
yea kinda odd how you don't have to pop the hood at all to get to them.
Old Sep 23, 2019 | 06:11 PM
  #40
simandang's Avatar
Super disappointed they don’t fit. The lens projector from my old headlight doesn’t line up with the headlight they sent me.
Smh
Old Sep 23, 2019 | 11:47 PM
  #41
simandang's Avatar
Looks like my projector is bigger and the holes for it don’t line up with the new housing. So I guess they sent the older G lights.
They asked me 4 times my model and the box has the right model labeled but the wrong lights
it’s probably going to cost a arm and leg to ship this **** back to Taiwan 🤥🤥
Old Sep 25, 2019 | 11:24 PM
  #42
simandang's Avatar
Well managed to get them installed. Tapped into turn signal to make them work as turn signals.
They work great however when the engine turns on the white rings shut off. They only come if I switch the parking mode lights on by setting the headlight switch in the position.
Everything else works
Old Sep 28, 2019 | 05:58 PM
  #43
horse86's Avatar
Range Rover, M5
How didn’t you get them to fit/line up? Thought you said they don’t fit? Looks good in the one pic. Need more
Old Sep 30, 2019 | 01:37 PM
  #44
simandang's Avatar
They ended up fitting with trial and error I ended up taking it to my friends shop. They did the front turn signals, the grill, brush guard and something else all at once. It took a few hours for sure.
Out of all these installs the front turn signal were the most frustrating. I have seen so many of these LED style on the G wagons but installing them is a total pain. You need to really bend, modify and hack job them to fit proper. If anyone is considering LED turn signals for the front I would avoid the 6 LED housing replacements. You are much better off with a CANBUS LED bulb and smoked housings and your total cost will be less than $50.
Old Sep 30, 2019 | 08:52 PM
  #45
obz's Avatar
obz
Mercedes-Benz W463
That's what I did on mine. Prefer the look too honestly. Looks factoryish.
Old Oct 25, 2019 | 10:48 PM
  #46
Willard Lee's Avatar
G63
Hi - I’m trying to put these same halo headlights into my 2017 G63 and has a couple questions for folks who did the install themselves.
1) on the new headlights I have, the plug for the halos are where the little city bulb goes on the OEM (the plug at 6 o’clock ). My city bulb never seem to come on with the headlights...so are folks hooking up the new halos with the existing halo drl? Or using the same city bulb harness... I checked with a volt meter and only get 5 volts coming out of that harness
2) while trying the swap out the existing xenon parts from the old headlight into the new, how does one disconnect the self leveling wires ( 3 wires) that seem to go into a cylinder where I cannot see any harness to unplug....while on the new headlight, it looks like there is a three wire harness for the self leveling function...
thx in advance,Will
Old Oct 26, 2019 | 07:08 AM
  #47
G63
thx in advance,Will
here are some pics from the new headlight to give folks context of what I’m asking!! I’m pretty familiar with this all as I had converted an older g550 to a g63 bumper ... and now recently have come back with a 2017 G63!!
first pic is the socket that runs the led halo... where if I connect the same attachment from my light it doesn’t work ( only get 5v coming out of the factory harness )
the next 2 pics are what I believe to be the self leveling thing, and it’s connector.... but on my oem headlight the three wires run inside that cylinder and it’s not a plug like in the picture!
Old Dec 7, 2019 | 01:59 PM
  #48
arsene2000's Avatar
g55
Anyone upgraded their headlights with 7" Morimoto Super7 bi-Led headlights ?
Old Dec 8, 2019 | 05:18 PM
  #49
arsene2000's Avatar
g55
are these alibaba lights LED headlights (including LEd bulbs and projectors), or just the assembly with Halo that you use with the pre-excisting HID projectors (which in my case won;t work since i have a halogen setup on my 2005 G55) ?
Old Dec 8, 2019 | 05:38 PM
  #50
SLWWGN's Avatar
E63s AMG wagon
The one I have is a complete swap. No use of the old parts.
