G63 Driver Side Water Leak
Im new here and hoping the community can help me out with an issue I'm having with my truck. I have a 2013 G63 with only 45k miles. Every time it rains, I get a puddle of water in the driver side footwell underneath the carpet. It's beginning to get irritating. Its caused my driver side AMG door sill to stop lightening up. Anyone ever experienced this issue or have some suggestions to fix the problem? My AC water drips to the ground fine.
I had a mechanic blow compressed air through the sun roof drains holes and they seemed to be unclogged. I would greatly appreciate and possible solution
If you have an antenna on the roof behind the windshield, is ti broken? Sealed ok?
I would tighten the wiper shafts, install new plastic caps with grease in them- common cause of leaks
Door seals on the body can contribute to leaks, but I think the plastic sheet installed in-between the door panel and door itself is a more common cause
I don't think your truck is old enough to need a new sunroof seal that's installed on the body, but those are another cause. But you'd see water stains on your headliner
The only has 45k miles,
these guys. They crack and let water in. Replace and fill with grease.
There's an assembly underneath that seems to get loose. As long as the shaft mechanism isn't frozen you should just be able to tighten.
can anyone think of something else?
https://mbworld.org/forums/g-class-w...ml#post8259877
Took everything apart and there's a steady light stream coming in from somewhere behind where the hood latch is.
Going to jump back in tomorrow morning, in the rain and take more stuff apart to find the culprit.
