G-class rust
Old Nov 1, 2021 | 01:48 PM
  #251
gmaschine's Avatar
W463
Originally Posted by JD101b
Get some oil under those seals ASAP.
Oil will only swell the rubber seal. There is nothing you can do but slow the process down by blowing any water or moisture out of there and you will eventually need a glass out repair job.
This repair is the owners right of passage to G ownership.
Old Nov 1, 2021 | 02:14 PM
  #252
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
I sprayed WD40 corrosion inhibitor under the seal in June of 2020. Pictures then and now show that the visible corrosion hasn't progressed at all. There is no visible swelling of the seals.
I should be getting my truck back today or tomorrow. The rust will be repaired but even with aggressive drying measures in place (climate controlled garage maintained at 30% humidity + fans) some moisture will be trapped. Good paint plus corrosion inhibiting oil is the only real way to prevent rust long term.
Old Nov 1, 2021 | 09:14 PM
  #253
JD101b's Avatar
Update
Old Nov 2, 2021 | 01:00 AM
  #254
djjoonie's Avatar
AMG GTs
Update
looking really nice!
Old Nov 2, 2021 | 01:03 AM
  #255
djjoonie's Avatar
AMG GTs
some updates on mine
Old Nov 2, 2021 | 10:49 PM
  #256
djjoonie's Avatar
AMG GTs
I had a short talk with my windshield guy today and I'm thinking about installing the windshield without the outside seal, just like the newer design. I don't think that outside rubber seal has anything to do with holding the glass in place other than holding salt water in place;(, what you guys think? my glass guy thinks its possible to use different method of use of glue or style of the sealer, but do you guys think its possible?
trying to think how to prevent this from happening again
Old Nov 3, 2021 | 01:36 PM
  #257
shiann's Avatar
2005 G55K
I've read about others trying this, but because of rigidity issues with the window frame bonded glass cracks fairly easily. Not sure where I read it though. May not be an issue depending on how/where you drive but there is a risk. I would be interested in doing this also if cracking isn't an issue.
Old Nov 4, 2021 | 09:21 PM
  #258
JD101b's Avatar
Old Nov 11, 2021 | 11:52 AM
  #259
JD101b's Avatar
Just found out that the windscreen is backordered for a few weeks. It's a Merc OEM part and is still on a cargo ship somewhere . Unfortunately, the windscreen rarely survived being removed so I had to get a new one. Good news is, the old windscreen was pretty pitted scratched up. Bad news is, the new one costs $900.
Old Nov 21, 2021 | 01:06 PM
  #260
valicaddy's Avatar
'95 E320C, '89 200D wagon, '93 rod bender
One thing to note is that it is very difficult to remove the windscreen without cracking it
Always cut the seal..
Old Nov 29, 2021 | 06:36 PM
  #261
djjoonie's Avatar
AMG GTs
Lil update on my end:
Almost ready for paint!
Old Nov 29, 2021 | 07:14 PM
  #262
JD101b's Avatar
Nice!
Old Nov 29, 2021 | 07:15 PM
  #263
JD101b's Avatar
Rust free!
Old Nov 29, 2021 | 07:17 PM
  #264
JD101b's Avatar
Having new glass makes such a huge difference. The streaks and pitting are gone, replaced by crystal clear glass.
Old Nov 29, 2021 | 07:21 PM
  #265
djjoonie's Avatar
AMG GTs
Thumbs up
Rust free!
Beautiful! Congratulations!
Old Nov 29, 2021 | 08:54 PM
  #266
JD101b's Avatar
Thanks!
Just finished pumping white lithium grease behind the front seal. That should keep any corrosion to a minimum.
I'll end up doing the same thing to the rear window seals too.
Old Nov 30, 2021 | 09:05 AM
  #267
djjoonie's Avatar
AMG GTs
Thanks!
I'm thinking about applying Fluid-Film under the rubber and all the body panels and frame. I saw rust testing and comparisons on youtube and it protects from rust like champ.
Old Dec 4, 2021 | 04:58 PM
  #268
Makbros's Avatar
G63
I was washing my 17 63 yesterday and notices the rubber seal around the windshield was bumpy. I lifted the the rubber and found the paint was blistering. Finished washing the exterior, detailed the interior and drove to the dealer. 30 minutes later I left with 122k check. Sold it back to them. Unacceptable for a155k plus vehicle to rust like this. BTW I purchased my g 3 years ago for 105k. So I don’t feel that bad. I really liked it and was planning to keep it forever.
Old Dec 4, 2021 | 05:02 PM
  #269
JD101b's Avatar
sorry to hear that.
do you happen to have more photos of the rust?
Old Dec 4, 2021 | 05:04 PM
  #270
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Just shows how in demand they are. You could have likely sold it privately for $50k more in this market.
The new ones seem to be much better in this regard but they are selling for crazy markups now.
Old Dec 4, 2021 | 05:05 PM
  #271
Makbros's Avatar
G63
sorry to hear that.
No, just that one. I was so pissed I just wanted to get rid of it before it got worse.
Old Dec 4, 2021 | 05:10 PM
  #272
JD101b's Avatar
thats understandable. Thank you anyways.
Old Dec 5, 2021 | 01:18 PM
  #273
djjoonie's Avatar
AMG GTs
Lil more update
It came out beautiful.
Old Dec 9, 2021 | 04:48 PM
  #274
djjoonie's Avatar
AMG GTs
Finally all done, the glass is in and no more rust!
Old Dec 9, 2021 | 08:31 PM
  #275
JD101b's Avatar
Looks great! Now work on preventative measures.
