DGI’s 2005 G55 Ownership Log
Old Oct 4, 2019 | 02:17 PM
dgi's Avatar
dgi
93 Mustang GT, 94 Corvette ZR1, 2004 CL55 AMG, 2012 MP4-12c
Service update:
Specialist found the bleeder screws for the differential lines seized up. They will soak with penetrating oil over the weekend (closed tomorrow) and go back at it on Monday.
I ordered the other stuff I need from FCP Euro and Summit Racing for the rest of the maintenance catchup game.
Summit:
3 quarts 75w90 (Differential)
4 quarts 75w140 (front and rear Diff)
FCP Euro:
Valve Cover Reseal Kit
Oil Cooler Gaskets
Oil Cap Wrench
Oil FIlter Housing Seal
Ignition Service Kit (Plugs and plug wires)
Should be a busy day or two once I get the truck back
Old Oct 4, 2019 | 02:27 PM
horse86's Avatar
Range Rover, M5
I use Tune2Air in all my cars for bluetooth works and sounds great but you need a USB AUX port
Old Oct 9, 2019 | 10:14 AM
dgi's Avatar
dgi
Got the truck back on Monday.
Coolant and brake fluid flushed. Diff bleeders still seized, going to tackle those springtime as there are no leaks in the system and everything works fine for the time being. Transmission has been serviced as well.
Parrot Bluetooth Kit is going back to Amazon as there are no adaptors for it and hardwiring the kit would take 4 labor hours to do... I'll just upgrade to a bluetooth headunit and get some modern functionality out of it. Just need to see what the easiest upgrade path will be.
Next up is doing the rest of the maintenance (valve covers, plugs, diff fluids, etc) and repairing my sagging headliner. Making progress feels good!
Old Oct 11, 2019 | 09:57 AM
dgi's Avatar
dgi
Best cupholder on the planet!!!!
Would have installed my passenger side cupholder as well but I didnt realize that side air vent was broken and cobbled together enough to stay in place.
Anyone have a spare passenger side air vent for sale lol
But seriously, these mount solidly and are perfectly positioned. They wont hold a extra large big gulp but my daily coffee tumbler or a bottle of water fit just fine
Old Oct 11, 2019 | 11:54 AM
mrtonyn's Avatar
1999 E320, 2008 S550, 2016 G63 AMG
How do you plan on fixing the sagging head liner ?
Old Oct 11, 2019 | 12:00 PM
dgi's Avatar
dgi
I got a quote from an upholstery shop in the area. $700 and 2-3 day turnaround
Im going to ask around a little more because $700 sounds a little excessive. I need to run the microphone wire for whatever bluetooth head unit i'm going to install as well as possible a front and rear dash cam so I'm not in a terrible rush but it needs to get done as the rear is in worse condition than I originally thought.
I really wanted to go with a dark gray alcantara but scrapped that idea because I'd have to redo all the handles, visors, etc to match and that would just be more trouble than its worth.
Old Oct 11, 2019 | 10:49 PM
  #32
mrtonyn's Avatar
I thought you were planning to do it yourself 😁.
Asked because my 1999 E class is sagging and was hoping to learn from you.
I have purchased some upholstery pins on Amazon for this purpose but have not done it yet. Not certain how it will look afterwards, it is the cheapest method I know of for now.
Old Oct 12, 2019 | 08:21 AM
  #33
dgi's Avatar
dgi
I considered it but thats one job ive never done and dont feel like fiddling with. If it was a smaller headliner it would be easier to do without any wrinkles (theoretically?) but something so large, i’ll leave to a shop
Old Oct 12, 2019 | 12:55 PM
  #34
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
I completely agree.
I gave them the tranny/brake/coolant flush as a thank you for hooking me up with the shop in New Hampshire that performed my PPI.
Oil changes are $129.73 at the specialist and the "Oil Change Kit" from FCP is $84.24. I figure its not too bad to have them do the oil change every other oil change and have their professional opinion on any maintenance that needs to be done.
Im getting a shopping cart together from FCP right now
congrats! I hope to keep my new 2019 for 25 years, so it’s nice to see this thread.
why not flush the brake lines yourself? One of the easiest DIY service items.
Old Oct 12, 2019 | 09:12 PM
  #35
dgi's Avatar
dgi
I got the impression that the diff lock lines were part of the brake system and didnt know if it was a simple flush like the brakes would be... turns out its a stand alone system. Live and learn.
Big modification today!!!
Ebay Lock Pins
When I tightened them all the way down they would be way too recessed in the hole so I applied some blue loctite and adjusted them to where I wanted them to sit flush when locked.
Another plus with these is that it should be considerably easier to reinstall door panels now as I hear it can be tough to fish the threaded pins back through the holes because they are too short? That was a good enough excuse to justify $29 cost
Old Oct 15, 2019 | 03:47 PM
  #36
horse86's Avatar
Range Rover, M5
just hope you don't get locked out with or without a hanger.
Old Oct 16, 2019 | 07:57 AM
  #37
dgi's Avatar
dgi
Another major modification done!
Bought it on Amazon. Grey stitching model was on sale as it matches my Designo stitching pretty well it worked out!
While im loving the truck more and more with each mile I drive it, it could use all the additional storage space I fan free up.
Should be able to get it up on the lift tomorrow after work and get started on the diff and transfer case fluids
Old Oct 20, 2019 | 08:52 AM
  #38
dgi's Avatar
dgi
Got the truck up in the air finally! Didnt have a 14mm Hex driver to get into the differentials and Home Depot /Lowes only stock upto 10mm (awesome) so I’ll have to wait until tomorrow for Amazon to deliver.
Had an issue with the drivers seat bottom cushion not moving. Bought a seat control panel from Ebay and swapped it out, seat works fine now :-)
Took some pics of the undercarriage to document the current rust situation. It looks worse than it is. Needs a bit of love but i’ll get to that this coming spring/summer
Old Oct 20, 2019 | 08:54 AM
  #39
dgi's Avatar
dgi
Old Oct 20, 2019 | 08:57 AM
  #40
dgi's Avatar
dgi
Old Oct 20, 2019 | 09:01 AM
  #41
dgi's Avatar
dgi
In this pic I raised the car ~3” to simulate a 2” lift and 33” tires
I dont think it would help my 5 and 3 year olds get in/out of truck if I lifted it so that may wait for a couple years. (Plenty to do in the meantime)
The good thing is that there would be plenty of room to get in the garage with a roof rack & a lift but any roof rack items would have to be loaded outside before a trip lol
If any of you guys/gals viewing my pictures see something that needs attention, please do not hesitate to speak up!
Old Oct 20, 2019 | 09:14 AM
  #42
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Actually things don't look too bad for a 15 year old truck. Looks like some clamps should be changed out along with some wire brushing some surface rust and coating with a rust inhibitor. The trouble with messing with the rusted clamps is that you start the chase to repair/replace the connected parts. Overall looks like you are in good shape. Truck has "good bones" from what I can see. Good luck with your project. Keep us posted.
Old Oct 21, 2019 | 11:15 AM
  #43
dgi's Avatar
dgi
Been looking around for a dash kit and harness adaptor for the Single Din Kenwood unit I bought the other day (to arrive tomorrow) and called a shop today that wanted some pictures of the connectors and back of factory Command unit.
10 min in the parking lot at work and:
put everything back together except the Command unit. Parts will be here on Wednesday!
Old Oct 22, 2019 | 12:28 PM
  #44
illest's Avatar
w210 AMG or S213
I have not tried these but it could be a nice upgrade from the old command.
https://www.ebay.com/itm/2din-7-CAR-...AAAOSwxD5cpG9e
Old Oct 22, 2019 | 01:18 PM
  #45
dgi's Avatar
dgi
i hear those Ebay/Chinese units can be hit or miss. Awesome idea but im gonna stick with my Kenwood for the time being only because I have used them before with good success
Old Oct 23, 2019 | 11:37 AM
  #46
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Could you take pictures of the surface rust areas?
Old Oct 23, 2019 | 11:39 AM
  #47
dgi's Avatar
dgi
I shared pics in posts 38-40 above
Old Oct 23, 2019 | 11:40 AM
  #48
JD101b's Avatar
sorry. Should have clarified better. I mean any rust on the body of the car.
Old Oct 23, 2019 | 11:56 AM
  #49
JD101b's Avatar
BTW...I think a lift would look great! ����
  #50
dgi's Avatar
dgi
oh! Only surface rust on the body is a couple very small bubbles under the paint around the rear window (trunk door) barely visible.
As I need to refinish a couple spots on the truck due to peeling clear coat, i’ll have the rear glass removed and rust addressed while im in there
