10.25 replacement screen install g63
Old Jun 23, 2020 | 09:57 PM
Svr21's Avatar
G
Hi all, hope all is well!
My new screen just arrived for my 2013 g63. There are no installation guide specifically for the W463 so I am wondering if any of you had done this install yourself so I can have some insights. I think I would need to remove the screen and the cd radio box but there are little informations I can find on the internet on how to go about doing so.
Thanks in advance!
If no one has done so, I will try to figure it out myself and post the process here.
Old Jun 24, 2020 | 07:27 AM
Kwesi400's Avatar
AMG G63
It’s a little complicated than it looks. There are plenty of YouTube videos but not for a G though.
Why not just take it to a professional audio shop to get it done to avoid screwing up/burning the harness? My Indy shop did mine in about an hour & half.
it took them a good time before they could get the factory screen out.
I was able to get a look when they were doing it... what i saw was the trim around the center console/middle air vents/radio pops off easily with a tool, once it’s off the screws holding the radio becomes visible, then you can unscrew and pull the radio out to get to the back of the wiring
Old Jun 26, 2020 | 11:29 AM
iluvspl's Avatar
bmws m6
@Kwesi400 are you happy with the screen so far? I heard rumors the audio quality when using car play thru your phone is not as good and the overall stereo volume thru CarPlay is lower. Do you experience any of this? any overall would you recommend it?
Old Jun 26, 2020 | 12:31 PM
Kwesi400's Avatar
AMG G63
Yes I love it. No complaints and I haven’t had any issues with it. Gives the car a modern feel.
the sound quality is still the same as factory if not better since the screen has a built in equalizer and “loud” button.
When I first initially installed though , sound was clear and high quality but I was getting static background noise when I stepped on the gas, I ordered a ground noise loop adapter for less than $10 on Amazon and that canceled the static noise. Sound is super clear and high quality even better than factory.
You also have the option to go back to your factory NTG screen. The screen retains all factory functions.
Old Feb 18, 2022 | 01:12 PM
nikos525's Avatar
Porsche
Thanks in advance!
Please post this as I’m on the fence about ordering this and fitting it.
I would want to fit it myself, so I would appreciate an installation guide!
I found this video on YouTube so it gives a good idea of how to take everything out:
Did you get the installation instructions with the kit?
Do you have to install the GPS antenna I couldn’t figure out why they would include that in the kit when the car has one itself!
Thanks Nik
Old Feb 18, 2022 | 02:46 PM
Bullishness's Avatar
2018 AMG G63, AMG E63s
I found this video on YouTube so it gives a good idea of how to take everything out: https://youtu.be/rUaCY1te2aY
Thanks Nik
Hi Nikos,
I purchased this and also wanted to try to do it myself, but my car had carplay and it was more confusing so I took it to a professional. It's just detaching the differential lockers, the radio, then make sure you follow the instructions that were given to you with the head unit to plug the wires in accordingly. In regards to the GPS, the GPS for your car is not the same as for this android unit. The android unit needs its own GPS in order to function correctly, but if you do not use it for its own GPS and only use Carplay, then you can skip the GPS.
Old Feb 18, 2022 | 04:26 PM
nikos525's Avatar
Porsche
Mine doesn’t have CarPlay, so hoping it will be an easier install. Yeah I’m not bothered about the gps as with CarPlay I’ll use maps.
If it truly is plug and play then it should be straight forward. I’m on the fence about whether to go for the 10.25 or the 12.3
Old Feb 18, 2022 | 07:26 PM
https://youtu.be/jG21GWikRS8
I got the 10.25 as probably mostly everyone here. 12 just looks a bit too tacky and too large and feels a bit out of place IMO
Old Feb 20, 2022 | 03:01 PM
black06c230's Avatar
mgLipGD
Is CarPlay built into the screen or is a dongle needed to have wireless CarPlay?
Old Feb 20, 2022 | 03:05 PM
Kwesi400's Avatar
AMG G63
A dongle is needed. They are like $40 on Amazon. Works great on mine
Old Feb 20, 2022 | 11:45 PM
Mine came with Carplay included with the screen, nothing needed to buy from Amazon
Old Feb 21, 2022 | 09:59 PM
mgLipGD
Link to the one you got?
Old Feb 21, 2022 | 10:01 PM
mgLipGD
I asked bc the dongle on my 2011 G55 android screen freak out often and I have to turn off the car to get CarPlay back. I’m sure a new dongle would help but going to upgrade to a 14-15 G63 and a screen without a dongles needed this time seems nicer.
however I know I will place the dongle in reach to unplug from the usb if I have to use a dongle again.
Old Feb 21, 2022 | 10:04 PM
https://www.aliexpress.com/item/1005...4ba54c4dKjI1iE
works great, but sometimes if you need customer service, their translated english might be difficult to understand so please be openminded to that. Otherwise, no complaints and it's the cheapest around.
