Adding a touchscreen...?
Old 12-31-2020, 12:41 PM
GFiveFifty's Avatar
2010 G550 & 2019 S560
Originally Posted by archprop
Hello. Did anyone come across installation instructions or videos? I’d love to understand the step by step prior to purchasing. Thanks
Try contacting Daniel from DMP on What'sApp. His number is +60 175521201. Mr. Seven from DMP can also be helpful. His number is +60 176071426.
Old 12-31-2020, 12:43 PM
GFiveFifty's Avatar
Originally Posted by FERDI_
Hello, my name is Cédric, I saw your post for installing new screen, i would like to make the same thing but I don't know how remove Comand online, can you help me and explain me how you did?
Best regard
Cédric
Old 12-31-2020, 01:00 PM
FERDI_'s Avatar
G63 AMG
You are right, Daniel and Seven helped me, very good assistance, you can call them, no problem.
Old 01-13-2021, 03:08 PM
archprop's Avatar
g550
Hi Folks! Has anyone been successful with replacing the back up camera in a 2013 to 2018 g class? (maybe something you have done with a radio upgrade?) I don't want to change the dash equipment and touch screen (yet but I do want the larger touch screen one day...but that's in the future).
My reason to change the camera is it is not in the best position for reversing....the spare tire is in the way so you cannot see if you are going to hit something.
I have installed a license plate frame back up camera on other cars (but with a new stereo update and I had to run a wire from the rear license plate through the car to the dash. I really do not want to attempt that. My thought was the wire to the back up camera must be in the rear door....so it should be easy to get to it and extend the wire to a new camera on a license plate frame. What do you think? Do you think the camera will still show the steering wheel position too (not a huge deal if it doesn't)? (these cameras are like $25 to $75 on amazon)
Old 01-14-2021, 08:49 PM
just1time's Avatar
s550
Can anyone comment on how satisfied they are with their screen. Satisfaction level for me is 7/10. Its a beautiful and much needed upgraded but i am plagued with glitches. Half the screen randomly goes darker or blank, pixels etc.. Took it back to the supplier and he replaced my unit with an "upgraded" version with inbuilt CarPlay. way better than the previous unit and definitely beats OEM. But yet Again, i experienced same glitches. (I should mention these glitches are random and don't happen often. I would say it happens 5% or less of time.
Trying to find out if i am a one off and just have had back luck with the two screens i have been provided OR if anyone else has experienced the same issues. These units are great and would be better if they ran efficiently with no glitches.
Old 01-15-2021, 09:54 AM
MikeHoncho's Avatar
g63
You're supposed to get your watch in the picture, not a BK cup.
Old 01-15-2021, 10:41 AM
  #32
black06c230's Avatar
mgLipGD
ahhha yeah gotta flex the Rolex
Old 01-15-2021, 11:10 AM
  #33
Limey Hooligan's Avatar
2012 G550 - Capri Blue Metallic, 2018 Porsche 911 GT3 - Silver
Old 01-15-2021, 11:44 AM
  #34
archprop's Avatar
g550
Hi Folks- I gave the camera replacement idea a bit more thought. Issue is the rear camera position doesn't really let you see if your spare tire is going to hit anything (i.e when parallel parking). I know I asked if anyone has been successful with replacing the camera (maybe with the radio upgrade), but maybe that isn't needed. It seems like relocating it to just be mounted under the spare wheel cover (aligning with the face of the cover) is all that is needed. The camera sits in the large housing on the door. What are the chances the camera has enough slack in the wire to move it about 3' lower? Has anyone opened the rear door inside panel to see the cord? Any idea how this panel opens?
Old 01-15-2021, 12:35 PM
  #35
FERDI_'s Avatar
G63 AMG
Hello everyone, I am completely satisfied with my screen bought from DMP, today it works perfectly, I have no problem, I upgraded it a bit by adding their 3D camera, the rendering is rather nice. that I haven't calibrated them yet. For the inside of the rear door, all you have to do is unscrew the inner cuff, you have 2 plastic covers to remove and you unscrew them, then you remove the door panel. I therefore changed the OEM camera, this one is simply clipped into its support that you can unscrew from the inside, attached some photos
Old 01-15-2021, 12:39 PM
  #36
archprop's Avatar
g550
NICE Upgrade! How does the 3D camera work? Do you have to install more than 1 camera (to get all 4 sides of the truck). I think the 2019+ might offer this, but it looks like yours is 2018 or older as well. The 3d camera might solve my issue of not being able to see if the spare tire is going to hit something.
Old 01-15-2021, 03:16 PM
  #37
FERDI_'s Avatar
G63 AMG
Better as that, cam 360 gives you possibilities to see your car completely outside, so look
Old 01-15-2021, 05:04 PM
  #38
shiann's Avatar
2005 G55K
Which 3D camera system did you use? I've been researching these for retrofit but have not seen that many good reviews on aftermarket systems that aren't crazy expensive.
Old 04-05-2024, 10:02 AM
  #39
Andy0331's Avatar
'08 CL63
just bumping this: has anyone else done this 3D camera upgrade? Who offers them & what is involved?
Quick Reply: Adding a touchscreen...?
