2019 G550 Rear Spare Tire Holder Modification
So I'm changing out my wheels and tires for my 2019 G550, to the 463 Industries Wheels and the NITTO Terra Grappler G2 tires (275/55/20). We got that all figured out through a previous post/thread.
I'm not only doing the 4 on the ground, but I'm doing the SPARE in the back as well (I'm going to abandon the rear tire cover). Now the problem.
1. The way it's set up now, the spare wheel faces backwards (and I want the face of the tire facing out).
2. The current bolts are not long enough to put the tire on facing outward.
So my question is has anyone done a spare mount modification to put the spare on (without the cover) facing out? I've seen it in picture, just can't find a modified hardware anywhere on the internet
Kindly advise. Thanks.
Here are a couple more: https://jackwagonoverlanding.com/products/spare-tire-reverse-mount
https://www.911motorsports.net/Mercedes-G-Wagen-Spare-Tire-Flip-Mount--1990-2018-G-Class-G500550556365-W463_p_39.html
https://mbworld.org/forums/g-class-w...-boutique.html
David Nussbaum || David@wheelsboutique.com || 786 249 0127 ext.2109
https://wheelsboutique.com/gallery/m...-on-anrky-an15
1) I’ll check the size of my spare, but I suspect it’s the same as yours. The reason why is because the spare tire cover would not fit over a larger tire. It already partially obstructs the rear visibility (we’ve removed ours completely).
2) If there is a TPMS sensor on the spare, you will see the info on the dash. But it takes a while to show up, and the tire has to be mounted on a driving wheel.
3) Not sure why you need to check the pressure of the spare. Just keep an electric pump in the car and inflate it to the proper pressure if you ever use it.
4) You can easily add a lock to the spare tire cover.
My spare tire cover has only a tube that inserts through the wheel hub into a receptacle in the mounting bracket and this all seems independent of which way the wheel is oriented. I don't think the MB spare tire cover design department dictates to the body design department how to mount the spare tire in order to accommodate the tire cover that it intends to provide.
2) TPMS systems do require a few miles of driving to collect data. My Lexus instrument panel shows the vehicle outline with 5 tire locations. Dashes appear instead of data in all 5 locations until pressure data is acquired. The G550 never shows any 5th tire location or data.
3) Spare tires always look fully inflated until mounted and the vehicle weight is dropped off the jack. Small compressors are a solution albeit very slow, and just another bother in bad weather or at night.
4) The aftermarket tire cover I purchased came with a lock. I already had installed security lug nuts on the spare wheel mount.
Re: (2), the MB TPMS sensors are only active when the wheel is turning. So you won't get a reading unless the wheel is rotating.
Spare Tire Reverse Mount
from 911 Motorsports. They are making them now for the 2019 Gwags and newer. Once I get it and get things mounted up, I'll post some pictures.It has been several months since we last posted on the forums - I hope you have all been well. We appreciate the mentions above and periodically throughout the forums. It is always an honor to see our name mentioned in discussion and we take great pride in that. Thank you.
As Sarlox mentioned above, after months of preparation, 911Motorsports has officially gone live with their reverse spare mount. We have also launched it on our site to be added to your next bundle of G Wagon upgrades and are ready to get these going.
With this generation's version (W463A), at least for the time being, there are three options to choose from based on your wheel/tire backspacing. We have instructions on our page to take the appropriate measurement to determine which size is best for you. The goal was to accommodate the widest tire without rubbing (currently ~12.5) and also minimize the distance the tire/wheel center of gravity stuck out from the vehicle.
You can find it here on our website:
911Motorsports Reverse Spare Mount (via Jack Wagon Overlanding)
or you can order directly from Casey at 911Motorsports.net .
Thank y'all!
Thanks!
