MY2019 G550 Oil Change
Old Oct 3, 2020 | 04:05 PM
streborx's Avatar
Top Answer: 1
G550
I recently did my G550’s first oil change at 5K miles -- two 5-qt. jugs of Mobil-1 10W-40 (Walmart @ $23 ea.), a Hengst filter (about $8) and 30 minutes of time. The skid plate drops off with the removal of 6 T-50 bolts, and the drain plug and filter are then easily accessible. The drain plug requires a T-40 drive and the filter cap requires a 24mm socket. I couldn’t see a drain plug on the oil filter cap (I was expecting to see a metallic color plug of some sort in the center of the cap) so I unscrewed the filter cap slowly and tried to minimize the mess as oil leaked out all around the cap. Once I had it off and in better light, I realized that the cap does have a drain plug in its center, albeit very subtle. A 10mm Allen wrench unscrews the plug to facilitate draining of the filter. Inasmuch as the cap, drain plug and internal support are all plastic, I ordered a spare set to have on hand. MB p/n 177 180 01 10 (about $50) provides the cap/drain plug, o-ring, internal support and filter. A couple weeks ago, I posted the service indicator reset procedure on this forum.
My neighbor heats his shop with waste motor oil and is always taking donations.
I wish MB provided a dipstick on this engine.
Oil Filter Cap with Drain Plug Installed
Oil Filter Cap with Drain Plug Removed
Old Oct 3, 2020 | 04:23 PM
DD0220's Avatar
2020 G63
Really useful information. Thank you!
Old Oct 4, 2020 | 06:16 AM
BCMgunner's Avatar
2019 G550
Great to see info like this on the forum. It is appreciated.
Thank you!
Old Oct 4, 2020 | 08:09 AM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Great info, thank you.
BTW, the recommended oil is 0W-40 or 5W-40, depending on outside temps. For almost everyone, it’s 5W-40. This is per the owner’s manual.
Old Oct 4, 2020 | 08:11 AM
Surge's Avatar
Do you have the raise the car to access the oil filter, or is there sufficient ground clearance to not require raising it?
Old Oct 4, 2020 | 12:08 PM
streborx's Avatar
Top Answer: 1
G550
I must apologize for my error -- yes, of course the recommended oil is 0W-40, which Mobil-1 labels as its European Car Formula, compliant with MB-Approval 229.3 and 229.5.
At the risk of starting a forum war, the G550 owner's manual states the oil should be MB-Approval 229.52 or 229.61. Mobil-1 ESP 0W40 conforms to this approval, but costs about twice as much, comes only in quart containers, and according to Mobil-1's information, is lower is ash, sulfur and phosphorous in order to be kinder to catalytic converters and diesel particulate filters (ESP = exhaust system protection). There doesn't seem to be any difference that impacts engine lubrication. Is anyone out there using an ESP formulation, and is this what dealerships are using? Is LiquiMoly or Motul in one of the approved weights better than Mobil-1 and worth the 2x cost?
Old Oct 4, 2020 | 12:18 PM
streborx's Avatar
Top Answer: 1
G550
There probably is enough ground clearance on the G, but I have 3 other vehicles with less clearance, and I find that driving any of them up onto wheel ramps ($40 at Walmart) is quick and safe, and provides another 6" of work space, in addition to ensuring better oil drainage.
Old Oct 4, 2020 | 11:00 PM
montreal red's Avatar
G550
this is great info! thanks
Old Jan 15, 2022 | 03:01 PM
084runnerltd's Avatar
2021 G550, BMW X5M, 2020 Toyota Supra LE
FYI: Just changed my oil on MY2021, the drain plug is a 6MM Allen, not a T-40.
I started with the T40 but it started to strip the drain plug. Took a closer look and a 6MM Allen goes in about twice as far and is snug.
(I was panicking for a minute, as I thought I stripped the plug).
Old Jan 15, 2022 | 03:54 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
The lower phosphorus, which is actually Zinc Dialkyl Dithiophosphate (ZDDP), is for environmental reasons and to protect the delicate new oxygen sensors that are being used lately. Almost all new oils have significantly reduced the use of this compound. Older cars will suffer more engine wear as a result because they depend on the compound to reduce metal to metal contact withing the engine.
Old Jan 15, 2022 | 05:22 PM
streborx's Avatar
Top Answer: 1
G550
I started with the T40 but it Stratford to strip the drain plug. Took a closer look and a 6MM Allen goes in about twice as far and is snug.
T-40 and 6mm hex are nearly identical in dimension, but the plug on my '19 is definitely a Torx (as are the skid plate bolts, but T-50). Guess my assembly line m176 was built on a Monday.
Old Jan 16, 2022 | 12:37 PM
Yes my skid plate was torx, but using a torx on my drain plug was stripping it. Maybe they changed something in different model years. Or perhaps the style of my torx bit affected it.
As mentioned, my torx bit would not seat nearly as deep inside the drain plug as my Allen did.
Old Jan 16, 2022 | 02:16 PM
streborx's Avatar
Top Answer: 1
G550
Does your drain plug look like this (MB p/n 178 014 03 00)?
Old Jan 16, 2022 | 03:10 PM
That is the filter drain, I am referring to the drain plug attached to the oil pan.
My oil filter housing drain was 10mm as you described.
Old Jan 16, 2022 | 03:40 PM
streborx's Avatar
Top Answer: 1
G550
The filter cap drain plug is a bit different as shown in the photo toward the top of this thread. The photo I just posted is an oil pan drain plug that is used with some m176 engines that also have a plastic oil pan. If your oil pan and drain plug are both metal, then the drain plug's MB p/n should be 000000-008789. I can't find any info about this drain plug's thread, length or head style. When I next do an oil change, I'll measure it and post its dimensions.
In checking around some parts suppliers, there's mass confusion over fitment. FCP Euro says this plastic plug fits my '19 G550 and autohausaz says the -8789 plug doesn't fit.
Old Jan 16, 2022 | 04:10 PM
Wow, I didn’t know any vehicle used a plastic drain plug, seems like a disaster waiting to happen.
I will slide under my G and take some photos.
Old Jan 16, 2022 | 04:32 PM
streborx's Avatar
Top Answer: 1
G550
I thought the same thing the first time I saw a plastic filter cap. Apparently this plastic drain plug is used on the m176 engine in the S-Class (see attachment).
Interesting that this service procedure specs 9 liters (9.5 qts.) for oil, while the OM specs 10 qts.
9 liters is the correct capacity.
Old Feb 5, 2022 | 06:41 AM
Marcus Duffner's Avatar
ML55 AMG, CL65 AMG, G63 AMG
I do all the required services on my cars by myself. ML55 400k Km, CL65 150k Km, G63 100k Km. Using only original MB oil filter, highly recommended from my side and others understanding this engines. After 20 years of using Mobil 1 and I am talking about the real Mobil 1 not anything sold under this brand label. I have changed to Castrol EDGE 5W-40 229.31MB 229.51 . My engines running better and smother with this oil. You can fill up your engine with whatever you like but get the OEM filter.
Old Feb 5, 2022 | 10:41 AM
streborx's Avatar
Top Answer: 1
G550
My OE filter is a Hengst (as is the plastic canister cap). I buy them from Rockauto, and they're about the same price as other non-OE brands. I read somewhere that fleece oil filters are recommended for synthetic oils (Hengst is), but I don't know why. What is your oil change interval? Re Mobil-1 are you saying that there are counterfeit jugs of the Euro 0W-40 formulation being sold? My last change was Castrol 5W-30 MB Approved - seems fine since I figured out the OM's spec of 10 qts. Is wrong -- 9 liters (9.5 qts) is the correct amount for the M176 (wet sump). Still miss having a dipstick. IMO, if oil level sensing is electronic, it should be a full time display, not buried 5 levels down a menu that you're supposed to scroll to while driving.
Old Mar 5, 2022 | 04:51 PM
Here is the drain plug, you can see the damage to the plug from initially using a torx on it.
Old Mar 25, 2024 | 06:57 PM
wopr's Avatar
1999 E320
Speaking of oil filters, Mercedes lists two different oil filters for the G550 and G63. One is white in color, synthetic filter media, and part number 1761800800. The second is yellow in color, OE paper filter media, and part number 2781800009. Both are made by Hengst and priced a few dollars in difference.
Old Mar 29, 2024 | 09:31 AM
wopr's Avatar
1999 E320
Optionally, if you purchase part number 1771803300, it comes with the whole assembly as shown.
Old Apr 26, 2025 | 05:17 PM
wopr's Avatar
1999 E320
New oil assembly with bypass valve. If you buy just o-ring and new filter, no bypass valve included. Since the bypass valve is all plastic, not sure how often this part should be changed and how does one know if it is defective?
Old Apr 27, 2025 | 02:31 PM
streborx's Avatar
Top Answer: 1
G550
As long as you're changing the oil and oil filter per the recommended interval (I do mine every 5K miles), operation of the bypass valve should never be an issue. It becomes critical if your filter gets clogged or if your oil becomes too thick to pass through the filter normally. As long as the spring plunger functions and there's no crud accumulated on the tube and around the spring plunger, I don't worry about it. But I do keep a spare cap and bypass valve with my oil filters just in case there's an unexpected failure.
Old Sep 28, 2025 | 08:09 PM
wopr's Avatar
1999 E320
Mercedes Benz MB 229.52 comes as 5W-30. Does it also come in 5W-40?
