Issues with lower side moldings bending out on ends
Old May 19, 2021 | 08:10 PM
Stugots5541's Avatar
G63
I have a 2015 G63 and I have noted that the lower black rubber side moldings that run along both sides of the truck just below the doors and just above the side steps, are bending out or away from the body. It’s at both the front and rear above the steps and on both sides. At first I thought the rear passengers were maybe stepping on them when exiting the vehicle. However I noticed that the exact same thing is happening in the front which is in front of the front doors. No way any one can step there! And on both sides!!
this has got to be a known issue. Anyone have comments and will MB fix it at no cost. It’s an expensive vehicle!!
thanks
Old May 20, 2021 | 03:51 PM
sprfrkr's Avatar
E350, W140 S, C63, G55, 420SEL, Prius, Dune Buggy, Ducati
I have the exact same issue on my 2007 G55.
MB will not fix this issue.
Old May 20, 2021 | 04:41 PM
G63
Let’s see how wide spread this is. I wonder if a heat gun can be used carefully to heat them up and carefully add some adhesive and push back
into place. They won’t move the way they are now since they are very hard rubber
Old May 20, 2021 | 04:54 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Welcome to the world of G ownership. It's ubiquitous.
Old May 21, 2021 | 10:02 AM
paulunm's Avatar
2000 G500
There's metal inside the plastic trim pieces, so it corrodes and expands. Easy to replace, there's a fold down strip that will expose phillips head screws. Look for rust on the body when you remove them, treat it before you put the new trim on.
Old May 21, 2021 | 12:07 PM
G63
if that’s the case is it not covered under MB warranty for corrosion ?
Old May 21, 2021 | 08:08 PM
paulunm's Avatar
2000 G500
I have no idea, I don't own anything nearly new enough to have a warranty...
Aren't most corrosion warranties "perforation" corrosion? Meaning, you have to have a hole in a body panel for them to cover a repair...
If it were me I'd just drop the $300 or so for a new one. Or live with it.
Old May 24, 2021 | 08:27 AM
sprfrkr's Avatar
You would need to have actual holes from rust in the body for that to even apply.
