Corrosion around lower windshield
Old Aug 29, 2021 | 10:46 PM
awwgood's Avatar
2015 G63
I have a 2015 g63, and I'm having corrosion below the windshield right under the rubber around the windshield. Does anyone know if Mercedes will assists?
Old Aug 30, 2021 | 08:25 PM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Search in this section. There is a thread of about 15 page on rust.
to answer: maybe. 50% dealer can help
Old Aug 30, 2021 | 10:38 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
See: https://mbworld.org/forums/g-class-w...lass-rust.html
Maybe, maybe not. I just got a quote from a very well respected body shop to repair lower windshield corrosion + some small areas on the driver side door sill and rear door hinge for about $1800, which is a lot more reasonable than I thought it would be. Assuming that the corrosion hasn't rotted away the frame, the fix shouldn't be that expensive.
That being said, I would highly recommend you look into corrosion prevention techniques to ensure your truck remains corrosion-free after you repair it. Some of these include:
-Always keeping your truck in a garage when not being driven
-Using a dehumidifier and fans in your garage to dry your truck out
-An oil-based anti corrosion spray applied to all body cavities (Waxoil, Fluid Film, NHOIL, etc)
-Learning how to properly hand wash your truck (NEVER run it through an automatic wash) and make sure it is free of road salt
-Painting the chassis with a rust inhibiting paint
Old Aug 31, 2021 | 01:09 AM
JD101b's Avatar
Should have mentioned that corrosion on these trucks is super common. Do you have any pictures of it? How many miles?
Old Oct 6, 2021 | 06:54 PM
awwgood's Avatar
2015 G63
I only have about 48,500 miles
Old Oct 6, 2021 | 09:46 PM
JD101b's Avatar
Looks identical to the rust problems I'm having.
Other areas you should immediately inspect:
-door sills
-bottom of all five doors
-all door hinges (especially on the rear doors)
-the surround around the moonroof
-pillars for the exterior rearview mirrors
Old Oct 23, 2021 | 12:49 AM
djjoonie's Avatar
AMG GTs
I had a tiny rust bubbling up around the windshield and you will be surprised what's hiding underneath!
Old Jun 10, 2023 | 09:57 PM
awwgood's Avatar
2015 G63
who did you get to fix your truck? and what was the cost?
Old Jun 15, 2023 | 10:42 PM
JD101b's Avatar
Can't speak for OP but a local body shop repaired the rust on my truck. Cost about $4k (including a few other areas around the vehicle)
