Is oil gunk/build up normal on top of the skid plate?
Old Sep 24, 2021 | 05:10 PM
simandang's Avatar
G63/RR LWB/W222 S550
Attached are pictures. I’ve had this issue for 4 years now. The dealer tells me it’s normal.
never drips from there but there is a lot of old oil build up and gunk attached pics
is this normal if not what is there to replace/check
thanks
Old Sep 24, 2021 | 06:58 PM
streborx's Avatar
Top Answer: 1
G550
Why does the dealer think it's normal? Oil leaking out of an engine is by design? If the drain plug is above the skid plate, check to see if the seal washer is missing.
Old Sep 24, 2021 | 07:45 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
This happened to me.
There was some minor surface corrosion on my front skid plate. I took it off to sand it down and low and behold, there was similar buildup on the inside. I had to take a hammer and flathead screwdriver to remove it...stubborn, stubborn stuff. Good news was, because it was basically hardened oil and dirt, the metal underneath was pristine.
Old Sep 24, 2021 | 07:50 PM
simandang's Avatar
Thanks for the reply.
Yeah I’m thinking I guess from previous oil changes and just be the design of that plate a lot of dirt and whatnot accumulates and just lives there.
One of these days I will remove it and do what you did as well.
Old Sep 24, 2021 | 07:53 PM
simandang's Avatar
The dealer basically told me during oil changes and other service oil will spill into it. They also claimed it’s not all oil but also dirt and moisture along with road debris that get lodged there.
Unfortunately I always forgot to ask about it when I was getting oil changes done at my independent mechanic.
I also never trust the dealer from them lying to me many times and also breaking and ruining stuff. So anything they say I don’t really challenge but take with a grain of salt.
Old Sep 24, 2021 | 08:00 PM
paulunm's Avatar
2000 G500
I'd agree with that. When I change my oil G500 (m113)- it's impossible to not have some of the oil from the pan drain fall into the front skid. It actually holds quite a lot of spilled oil!
But, any oil you're leaking from valve cover gaskets, oil cooler, power steering reservoir, steering box- has the potential to fall into the skid plate too..
Old Sep 24, 2021 | 08:15 PM
JD101b's Avatar
Yes, a lot of the "gunk" was dirt, sand, etc. Or at least I think it was. It has a fine granular quality to it, along with the grease and smell of oil.
Old Sep 24, 2021 | 09:13 PM
paulunm's Avatar
2000 G500
Well the dirt wouldn't accumulate like that in a sort of solid form without some oil mixed in.....
