285/50/R20 Tires on G63 HELP!
Old Dec 24, 2021 | 02:12 PM
Bullishness's Avatar
2018 AMG G63, AMG E63s
Hi guys! I just got new tires for my G63 W463. The stock are 275/50/R20 Advan STs and I needed all seasons for the winter time. So I bought Michelin Defenders 285/50/R20, after installing, I see that on the bottom it's being crushed pretty bad that the side walls of the tires are budging out. Is this normal? Should I fill more air in the new tires? I've filled it to 35 PSI with nitrogen, recommended was 32/33. Or these tires aren't a great fit for my rims? Any help would be appreciated! thanks!
Old Dec 24, 2021 | 02:56 PM
z168's Avatar
3phase-4pole
got a pic? 285 on a 9.5 is pretty normal even for lower profile, 40 or 35, series tires
Old Dec 24, 2021 | 05:44 PM
th
Thanks for your reply
Old Dec 24, 2021 | 05:49 PM
are these normal?
Old Dec 24, 2021 | 06:22 PM
streborx's Avatar
Top Answer: 1
G550
Are you sure your pressure gauge is accurate?
Old Dec 24, 2021 | 06:25 PM
yes it was filled at a professional tire shop
Old Dec 24, 2021 | 06:26 PM
Also my tpms saying the same
Old Dec 24, 2021 | 08:28 PM
z168's Avatar
3phase-4pole
I've even put 295/40/20 tires on a 9.0" width wheel (not for a G) and it didnt bulge that way.
might be possible its not on even pavement. I noticed the tire is sitting on an uneven driveway. the other tires are like that I assume?
shiann's Avatar
2005 G55K
You can probably increase to 40psi without issue. Max is 50psi for those tires. Load rating index looks fine when compared to the OEM Pirelli's but it does look pretty 'flat'.
Just to make sure, these are the tires you got right?
https://www.tirerack.com/tires/tires...um=85HR0DLTXXL
Old Dec 24, 2021 | 08:46 PM
streborx's Avatar
Top Answer: 1
G550
I have Defenders on my Wrangler during summer months (different size though), and they don't bulge at 35 psi. However, it's a much lighter weight vehicle.
Old Dec 24, 2021 | 10:02 PM
Sorry I don't think your link worked. This is the one.
https://www.discounttire.com/buy-tir...tx-m-s/p/37671
Old Dec 24, 2021 | 10:03 PM
somewhat, but when I change the location of the driveway, the passenger front ones are still bulging the most. I filled it to 37 and it is a little better, may have to fill it to 40..
Old Dec 24, 2021 | 10:04 PM
Also the others don't bulge as much. Could it be this tire is defective?
Old Dec 27, 2021 | 04:35 PM
z168's Avatar
3phase-4pole
then thats an indication its just that one tire. I would have that looked at or even just remounted
P.S. also check the date code on the tires if its under 90 days
Old Dec 27, 2021 | 10:35 PM
just1time's Avatar
s550
I have 285/50/R20 and they are fine. No issues whatsoever. Better ride quality than stock IMO.
Old Dec 28, 2021 | 01:00 AM
hey how do I check the date code? What's a good date code for this tires? Like a few months old?
Old Dec 28, 2021 | 01:01 AM
did you fill your fronts to 40 psi? It looked better when filled it to 40
Old Dec 28, 2021 | 01:53 AM
z168's Avatar
3phase-4pole
Its a 4-digit code on the sidewall that shows the week and year of production. ideally it should be within 3 months from sale.
