2011 G55 front license plate holder removal
Easily removed the license plate holder.
These two brackets remain and need to be removed.
You can see the screws coming up from below through the bumper that fix the metal brackets to the bumper.
Used the dremel to cut the bracket and bolt off from above.
Managed not to scratch up the front bumper paint.
Need to get some plugs.
Will look much cleaner without the front license plate and holder!
Glad you were able to get it off without any damage. Now just find some plastic/rubber plugs on Amazon and call it a day. I wish I could run without a front plate.
Sorry for reviving an old thread, but I’m trying to do something similar. I’m gonna use a dremmel as well to cut off the bracket and screw. Did the other part of the screw just fall out easily, or did it get stuck somewhere? That’s my biggest concern. I have a 2002 G500 for reference.
Good luck.
I took a vice grip to hold the screw from the top and twisted the bracket. When the top of the screw got smaller, I took needle nose pliers underneath the bracket to hold the screw (placing a microfiber underneath the pliers to avoid scratching the bumper) and continued twisting the bracket. With some WD40, time, and effort, I managed to remove them.
As for the screws, since the needle nose pliers are already holding the screws in place after the brackets are removed, I placed a piece of cardboard into the grill beneath the screws to slip them out.
Anyone know what size plugs are needed to fill the hole?? Thanks
