Help needed- 14 G63 turbo coolant leak
I found a puddle under my 2014 G 63 and opened the hood to investigate. It seemed like the leak was coming from one of the 2 lines going to the driver side turbo( I’m guessing it’s the return line.
Is this replacement something that can be undertaken in diy fashion at home ? Or should I take it to the dealer ( costs??)
I removed the fan and saw where the lines were, but it’s tight in here.
thought I would ask the forum on what other people had done. Thanks
Crack in the coolant line to driver turbo
This is not a G-specific issue.
Use the search function on this site and look for posts from @arsupisemnet @BlownV8 and @Max Blast and others.
ive searched it all, located the leak after taking the radiator fan out.
What I need help with, is how to unbolt these lines, and how to slip them out of the busy engine bay. I’ve searched the forums and googled it too.
additionally, check clubg
