2016 g63 coolant leak
Old Mar 15, 2022 | 03:49 PM
3ktt's Avatar
gl550
What’s the best way to access the front area below the radiator. I got a coolant leak front drivers side dripping from the hook opening . Can’t see anything from the top. It s 2016 with 18k miles
Old Mar 16, 2022 | 08:23 AM
Tonymaz7sm's Avatar
2016 G63 AMG
Had the same problem. took it to the shop so i dont know the steps on removing, but the cost of the repair for me was $600. 2 coolant hose needed to be changed. Goodluck.
If youre trying to understand how to remove the bumper only, i would refer to car wrapping shops, they always know how to take the car apart.
Old Mar 16, 2022 | 11:46 AM
EnigmaAW's Avatar
2021 G63
I just had the same problem, but my coolant hose completely blew and puked out all the coolant. Had to get towed to the dealership. I was hoping my CPO warranty would have covered it, nope. CP but the dealership did give me a substantial discount since my factory warranty just expired in December.
Old Mar 16, 2022 | 09:07 PM
3ktt's Avatar
gl550
seems like a common issues on these
Old Mar 18, 2022 | 12:53 PM
slk320's Avatar
Literally just picked it up from the shop - exact same problem. Cost me $300.00 to replace both coolant hoses at a local Mercedes Indy shop.
Old Mar 19, 2022 | 03:16 PM
MikeHoncho's Avatar
g63
I thought my hoses cost more than that from the dealer.
Old Mar 21, 2022 | 12:52 PM
slk320's Avatar
Radiator hoses - part 463 501 91 84 - $166.80
Dealers love ripping people off
Old Mar 22, 2022 | 08:36 AM
PeriodCorrect's Avatar
2011 G550
Quote- dealer. That’s the issue. The user you quoted said Indy shop
Old Mar 22, 2022 | 01:00 PM
3ktt's Avatar
gl550
Shop said its radiator leaking and needs new radiator
Old Mar 22, 2022 | 04:08 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
Smile
That’s a bummer. My 2017 G63 just had its radiator replaced. $$$$. It was in for service and the tech noticed a crack in the radiator. The warranty had just expired, but the dealer took care of it since I’m such an awesome client of theirs.
Old Mar 22, 2022 | 11:41 PM
2011 G550
Have an Indy do it
Old Mar 23, 2022 | 08:03 PM
MikeHoncho's Avatar
g63
There are two hoses that you need. Also, part 463 500 23 88.
Old Mar 23, 2022 | 08:04 PM
MikeHoncho's Avatar
g63
Mine did the same thing, and on a whim I took it to a local radiator shop. They recrimped the aluminum to the plastic ends for no charge. They loosen up after cycling through temperature changes.
Old Mar 14, 2023 | 12:53 PM
newbieG63's Avatar
2015 G63
I know this thread is from a year ago, but I've recently had a slow coolant leak and suspected the usual hoses that tend to go bad. My 2015 G63 has 50k on her. Indy shop that specializes in G wagons says besides replacing several hoses and belts in the area that can be accessible once work is underway, he's also recommending replacement of the radiator. He showed me a picture of the underside of the radiator where the plastic is crimped on to the radiator that is sweating and will fail soon. Big $$$ to replace radiator now too and MB wanted to vin number of the truck before releasing the replacement radiator.
Several questions. Anyone else have this issue? Is it typical that these radiators fail in this manner and could this be a potential recall issue with MB if enough cases arise? One poster mentioned having a radiator shop re-crimp the metal hinges tighter to the plastic but I don't see that as a long term solution. I'm going to go ahead and have radiator replaced now for $$$ instead of $$$$ later but I'm not happy about it...
Old Apr 12, 2023 | 12:12 PM
Hershey's Avatar
2011 BMW E92 M3 || 2008 MBZ W211 AMG
Just had my radiator replaced as well. 2015 G63 with 67xxx miles. started as a leak in the radiator then replaced that. 2 months later....one of hoses blew open and replaced that as well .
Old Dec 26, 2023 | 12:10 PM
emmholla's Avatar
Panamera Turbo
This repair isn't covered under warranty? I'm sitting on the side of the road with a coolant issue now. I just got this truck may three weeks ago. Hopefully they covered.
Old Dec 27, 2023 | 05:39 PM
emmholla's Avatar
Panamera Turbo
Looks like it was the upper rubber hose that split loose on my truck. The repair wasn't covered. Cost me a grand to fix. Should have the truck back tomorrow. All is well that ends well, I suppose.
