My 2011 G55 with 4x4 upgrades
Koni Raid Red shock upgrade... HIGHLY recommend.
Smaller pulley installed and long tube headers(it screams)... next is eurocharged tune
Need to get LeTech roof rack, install LED front light bar and looking to get the 3 led clearance light bar for the rear. Does anyone have that part number?
Yes thats my older ML63 as a daily driver because this is just too insane to drive daily.
Tibus has been, well...a challenge. Their items are coming from China, not Japan. That said, I put on 10-12,000 miles on the portals and have no issues. Make sure you rust proof them. They rust fast otherwise and look like crap.
I used the Koni Raid red shocks as upgrade... fantastic shocks for the price. Best upgrade I did. You will also need 2in coil upgrade in the front and can get away with 1in rubber spacer in the rear. You will need this for tire clearance if you want to do 35 or 36 in tires.
It drives FAR FAR better now than as it did as a normal Gwagon. Softer ride, wider stance...
Have you used Kubay before? I follow them on social media but I’m not sure how the quality is and if I would get scammed.
Your truck looks nice. I built mine from scratch during COVID nightmare of supply chain chaos. They did a great job on the filament of fenders and front bumper. Tires are HUGE. it will be a ***** to get in and out of. Looks like they already have the Koni on there, its popular in Japan. You are going to want to tune it... the added weight with only 469hp is very sluggish
Im sure portals hold their value well so selling them would likely net most of the expense spent on adding them, sans labor.
Why are they difficult to remove? Do they require drilling?
Portals are expensive and will retain most of its value.
@PeriodCorrect I've seen a handful of portal G63s (non factory Squared) on the market the last 4-5 years. Not sure they hold their value any better, and not sure you will get your money back out of them. The few I have seen sit on the market for a long while if the owner is trying to recoup what they put into them. They tend to sell when priced closer to other non-modified ones.
This one has been sitting on Autotrader for a good while:
https://www.autotrader.com/cars-for-...=myATCsavedcar
They even did a color change recently to try and freshen up the marketing. The last far lower mile one of these I saw ended up going for low $100K range after it had sat on the market for 4-6 months in this price range. People are wary of heavily modified vehicles. Your buying pool shrinks up when you start doing these major changes. That being said, I'd buy a portal G all day long, but I'm far more of an enthusiast than your average G buyer. @princemarko 's is great, and definitely the type of build I have considered in the past!
Yes, the Tibus portals on my G55 w463 bolted on. The welding that was done was just to secure the support bracket.
I just sold my modified 911 and I didn’t recoup any of the mod money. It’s always a losing proposition unless you revert back to stock. I’ve found desirable mods are easy to sell, though.
