2018 G63 whistling over bumps
Old Apr 5, 2023 | 09:27 PM
WTC43AMG's Avatar
2018 G63, 2018 C43, 2018 GLS450
Hi everyone,
First time post for me. I bought a 2018 G63 last August. Over the winter I started getting this strange whistle/squeeking over bumps. It's coming from the front driver's side. Going through posts on this site I thought it might be the hood as others described, but I fixed that already.
Car makes no noise when shaking it and no noise when opening and closing the doors.
Does anyone have any ideas what it might be? It's been to Mercedes numerous times and they haven't figured it out.
Please help! It's killing me.
Please see the video link below
​ thanks in advance
Old Apr 6, 2023 | 07:27 AM
places's Avatar
No more MB:(
I couldn't hear anything, sorry. My hood squeaked, added electrical tape and it stopped.
Old Apr 6, 2023 | 08:28 AM
WTC43AMG's Avatar
Sorry it's more towards the middle to end of the video. High pitched
Old Apr 6, 2023 | 09:23 AM
WillinMA's Avatar
2020 G550
If its the sound at around 9-10 seconds in your video, I'd look at putting gummi pflege on the rubber gasket around the door. Also, try adjusting the door strike, so its a little further in when you close the door - sometimes that fixes the squeeking as well....
Amazon Amazon
Old Apr 6, 2023 | 10:52 AM
WTC43AMG's Avatar
https://www.amazon.com/nextzett-9148...004B8GTQG?th=1
Thank you. That is the part in the video. I'll try that. Just purchased from your link and it'll be here tomorrow!
Old Apr 6, 2023 | 01:44 PM
WillinMA's Avatar
2020 G550
Cool...When I had my W463 it did the exact same thing and putting this stuff on every 3 mths or so made it go away. the first time you do it, I'd run over the gaskets a second time after the first coat dries. Then let us know if it went away
Old Apr 15, 2023 | 11:26 PM
WTC43AMG's Avatar
Noise is still there. I applied 3 times to each door of the car. Amy other ideas?
thanks
Old Apr 19, 2023 | 01:27 PM
WillinMA's Avatar
2020 G550
thanks
Did you do the rear door as well along with the 4 doors? I'd do that first.
If its still there, then you'll notice on the door strike on the car, there is the round part that the latch attaches to...wrap either duct tape or electrical tape on the round cylinder part where the door latches onto...that will also tighten up how the door stays shut...or you could try adjusting the door strike itself if the door isn't flush the the body when shut...
Old May 27, 2023 | 08:10 AM
WTC43AMG's Avatar
Is this what you are referring to?
Yes I did all the doors.
Thank you very much for your help.
Old May 31, 2023 | 11:29 PM
britm3's Avatar
SC430
Feel free to IM me - fairly certain I had the exact same sound on my 2017 - essentially you are hearing the hood moving with the squeak/whistle coming from the hood support rubber pads where they contact the support bar when closed - easy way to test - grab the brush bar and shake the car, you should hear the sound that gets transmitted into the cabin.
Old Aug 16, 2023 | 08:55 AM
WTC43AMG's Avatar
Tried everything above but the door striker. Still have the sound. Actually sounds like it's coming from the back. Any last things to try?
Old Sep 7, 2023 | 08:19 AM
DPG's Avatar
DPG
2013 G63
Is it the light squeaking noise that you’re referring to in the video? If it is, I adjusted the stoppers on the hood, put electrical tape on the body at the contact points, and sprayed WD40 on the hinges on both sides. The WD40 is what really made the squeak go away for me.
