How to best attach this light to my car?
Old Apr 15, 2023 | 10:24 AM
marklee127's Avatar
2011 Mercedes-Benz G-Class G350 BlueTEC Auto 4MATIC MY11
Any idea how to attach this light to my car?
Old Apr 15, 2023 | 10:49 AM
georges.email's Avatar
2022 GLS450, 2013 G550, 2007 FJ Cruiser, 1970 VW Beetle, 2003 JEEP Wrangler, 2020 GL550
what i might do. . .
Couple things. I love the coating on your front. I had wondered what that might look like to get it rhino liner'd. If this was me, and this was the location that you want to put the light (which i do think is a good location, i would either hammer out those l shaped brackets to they were flat and then attach to the side of the base, or i would hammer them flat to get the shape and then fab some new brackets and attach to the side of that box. I would put the nut on the inside of the box and use black flat or thin style bolts so the mounting bracket doesnt have to big fat bolts on either side.
Old Apr 15, 2023 | 01:20 PM
streborx's Avatar
Top Answer: 1
G550
Can you flip the angle brackets around so that the mounting holes are underneath the lightbar?
Old Apr 18, 2023 | 09:43 AM
croat's Avatar
02 ML320
Bend/straighten out brackets and screw into license plate holder.
Old Apr 19, 2023 | 03:45 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
You likely can find a slightly longer L bracket if need to reverse the direction of the mount to being under and use it that way - not sure how firm that plate mount is however....
is that Rhino liner or ?
Old Apr 19, 2023 | 04:25 AM
bishop64's Avatar
2021 S450 4Matic
First off, I think the light assembly should not sit directly on top of the license plate holder, ie not touching the holder (vs pics # 8 and 9).
Instead, it should be raised (say, 1cm) above, providing a gap so that the light assembly can be freely rotated up or down to provide the most suitable angle of light to suit various circumstances.
If so, flipping each L-shaped angle to make its mounting hole underneath the assembly might not (or just might) give enough clearance.
Also, flatten the L-shape angles to become an I-shaped one might also be not long enough to raise the light assembly slightly above the license plate holder.
So, the best option is to DIY fabricate a suitable length bracket for screwing onto the side of the license plate holder?
Old Apr 19, 2023 | 05:56 AM
Texas E63's Avatar
Some options also may exist for a U shaped bracket that could mopunt ot the plate mount - my real concern would be it's rigidity.... LED's are great when solidly mounted but if they bounce the flicker is brutal..... I had to double the thickness of the stainless of my hood mounted Ditch lights on my landcuiser to overcome that...
a sample idea of the mount perhaps.... https://www.blackoakled.com/collecti...u-type-bracket
Old Apr 19, 2023 | 07:03 AM
bishop64's Avatar
2021 S450 4Matic
Regarding vibration, make sure to have some rubber bearing/bushel at the contact point.
In fact, this mounting bracket might be a good idea:-
Amazon Amazon
Old Apr 19, 2023 | 07:36 AM
hyperion667's Avatar
2012 CLS63
Duct tape is great but Gorilla tape is WAY stronger.
