G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
dashcam - fitcamx
Old Apr 11, 2023 | 10:43 PM
RedPill's Avatar
2025 G63MB, 2022 G63MB
dashcam - fitcamx
has anyone tried this out?
https://fitcamx.com/collections/merc...omeeReviewsApp
Old Apr 12, 2023 | 03:35 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Thanks for sharing I going to buy it and try it out
Old Apr 13, 2023 | 02:45 PM
myfirstg's Avatar
G550
That looks fantastic! Will need to get rid of my Amazon special one for this. Thanks for sharing.
Old Apr 16, 2023 | 09:31 PM
Hodog16's Avatar
2026 G63
I just installed it tonight and damn it's so easy to do.
John's picture from the original dashcam thread will help you a lot:
Harness picture
You pop off the central piece and then work around the edges of the larger shroud and it should easily pop off without much force. The biggest pain in the rear is the central piece is tied into the larger piece with the plastic anchors (see John's thread again) which you have to free one side by pinching in those barbs in order to get around the rear view mirror.
After that pop off the original harness, plug it into the adapter then connect one end back into the harness and the other to the camera. Pop in the new shroud and central piece and done. Took me like 10-15 minutes total.
Hopefully it works as well as it's designed.
Old Apr 16, 2023 | 10:17 PM
RedPill's Avatar
that's awesome!
I actually got the blendmount to work by purchasing an extra link set from blendmount direct for the radar detector. I want to get rid of the vantrue dashcam that's glued to the windshield. I bought the fitcamx with the intention that even if it were to go kaput, I'll at least be able to use the other end of the fitcamx's power cable to power a different dashcam without having to worry about wiring of any sort.
Old Apr 17, 2023 | 08:59 AM
Chedman13's Avatar
Harness picture
Thanks for sharing! Which one did you get? Just the front camera or did you also get the rear camera? The rear camera seems like so much more work to hide the wire to the rear.
Old Apr 17, 2023 | 07:24 PM
Hodog16's Avatar
2026 G63
Got just the front camera. Downloaded the app and works great!
Old Apr 18, 2023 | 12:47 AM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Just ordered 3 sets of camera due to reviews here
Old Apr 21, 2023 | 03:55 PM
ElioVentrella's Avatar
2013 Mercedes SLS GT AMG, 2015 S550 coupe, 2016 AMG GT coupe, 2021/22 Mercedes-Benz G550
One thing!
I suggest you disconnect it every time your car goes into service because by connecting that harness, you are violating your cars warranty!
Harness picture
Old Apr 21, 2023 | 08:57 PM
Hodog16's Avatar
2026 G63
Unless the rain sensor goes out not worried about that affecting warranty.
Old Apr 23, 2023 | 09:49 PM
RedPill's Avatar
@ElioVentrella didn't cross my mind, but probably shouldn't. mirror tapped quite a few in the past especially bmw's even the M's but nobody complained.
update - just like @Hodog16 mentioned earlier, installation was a breeze. captures a nice 4k image and the sound is also pretty good. you don't have to fiddle with the alignment so that's great too.
Old May 1, 2023 | 12:15 AM
Venom-AMG's Avatar
Super easy install, literally 10 mins for the gwagen
Daughter 2024 Macan was a different story, spent 1.5hr and still cant the 2 tabs to latch during re-install.
Old May 8, 2023 | 11:49 AM
Chedman13's Avatar
Can anyone post some finished install pictures?
Old May 9, 2023 | 02:33 PM
RedPill's Avatar
Old May 9, 2023 | 02:52 PM
Chedman13's Avatar
Thanks!
FYI for those buying, use coupon code piki10 for 10% off!
Old May 10, 2023 | 06:32 PM
Hodog16's Avatar
2026 G63
From outside
Old May 20, 2023 | 06:35 PM
GrnLantern's Avatar
SLS
Nice! Thanks for sharing these photos.
Will have to grab a couple.
Old Jun 1, 2023 | 03:06 AM
Sbyri97's Avatar
G63 (W463A)
Hows the video quality on the fitcamx? Do you have any samples to share? Im deciding between the fitcamx and the Viofo A139 Pro (for the new Sony Starvis 2 sensor).
Old Jun 1, 2023 | 03:00 PM
Hodog16's Avatar
2026 G63
Video quality is good having had multiple dash cams. The ease of installation makes the fitcamx a no-brainer for G in my mind.
Old Jun 23, 2023 | 08:52 PM
RedPill's Avatar
here's a screengrab from the app itself..
Old Jul 25, 2023 | 03:09 PM
Chedman13's Avatar
For those that have this, mine does not automatically turn off when I turn off the car.
It continually records and slowly drains the car battery.
I tried resetting it and also tried long pressing the power button to turn off. It does turn off, but then starts back-up again (without me turning it on again). This is whether the car is off or on. When the car is off, I make sure it's completely off and open the door then re-shut it.
Wondering if I got a faulty one or not.
I have one on my Panamera and it turns of and off (all lights go off when car is off). Right now the blue light is always flashing whether on or off (car).
Old Jul 25, 2023 | 04:20 PM
RedPill's Avatar
mine does shut off. no recorded files either.
Old Jul 25, 2023 | 05:52 PM
Chedman13's Avatar
Thanks! I might have a defective one. When you press and hold the power button, does it stay off?
Old Jul 25, 2023 | 08:51 PM
cjpatel's Avatar
SF90, G63, M8, V12Vantage, E46 M3
Wow, going to have to try this. Great share!
Old Jul 25, 2023 | 10:09 PM
vivamilano's Avatar
Mine works like a charm. Super simple to install. Files download with ease. All around satisfied
