G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
G63 4X4 Squared spare tire wheel size?
Old Sep 30, 2025 | 05:50 PM
The Butcher's Avatar
G63, G65
Can anyone confirm the wheel and tire size for the spare tire on a 2022+ G63 Squared? I assume the tire and wheel size is same as the other 4 tires/wheels (325/55R22), but wanted to be sure. Thanks.
Old Oct 1, 2025 | 08:02 PM
Alexie's Avatar
Yes, it's a full-size matching spare. Same 325/55R22 wheel and tire as the other four.
Old Oct 1, 2025 | 08:16 PM
RedPill's Avatar
2025 G63MB, 2022 G63MB
yes same size
Old Oct 2, 2025 | 06:25 AM
G63, G65
Thank you.
Old Oct 2, 2025 | 08:16 AM
streborx's Avatar
Top Answer: 1
G550
I'm not familiar with the 4x4^2 standard equipment. Is there a spare tire cover like the G550 and G63 have, or it the spare mounted naked?
Old Oct 2, 2025 | 08:48 AM
G63, G65
It's on a swing out carrier that has a carbon fiber cover, but only around the center of the wheel. The tire itself is exposed.
Old Oct 2, 2025 | 09:13 AM
streborx's Avatar
Top Answer: 1
G550
Thanks -- my '19 G550 came wth 275/50R20's mounted and a 265/50R20 spare because the spare tire cover is too small to cover the 275 tire, and MB is too cheap to retool the part on a $140K car on which it's profit margin is already slim. Nobody at MB has ever given thought to what happens to the tire cover after you hang your flatted 275 on the spare rack (much less the impact on the gearboxes of driving with a mismatched tire dimension).
Old Oct 4, 2025 | 06:46 PM
hard top's Avatar
2012 Land Rover LR4 5.0L V8 LUX HD
I bet the jack for that rig is pretty tall to be able to lift at the frame enough to get a wheel up.
Old Oct 5, 2025 | 09:00 AM
streborx's Avatar
Top Answer: 1
G550
It's a hydraulic bottle jack that by itself appears untrustworthy. I carry in the vehicle a foot square x 3/4" piece of plywood to set the jack on, a collapsible wheel chock for stability, a flashlight and a foam knee cushion since placement of the jack is not obvious. I also carry a tire inflator and a flat fixer slime product. MB assumes everyone calls roadside service. Here in the west, you can wait several days for a rescue.
Old Oct 5, 2025 | 07:19 PM
hard top's Avatar
Check out a 4X4 squared in person standing next to it. They are tall, I saw one in Vegas. The bottom of the frame is high, the whole rig is monsterous. Its not just a G550 with mods, the drive train has portal axles and huge wheels so I was curious about the jack that is offered for it from the factory. Not that I could ever afford an offroader like that, but if you want ground clearance the squared is the best on the market for height and could compare to the Hummer H1 for clearance and such (but not payload)..
