Took the Brush Bar off my 2025 G550...
Super easy!! If you zoom in on my picture you'll see the removable plastic pieces on the ground, they pull outwards from the top of those pieces, the red plastic tool on the ground you see helps without damage to the plastic, they pop right out. Then you can see two large bolts on each side, slowly loosen them, don't worry, the brush guard won't drop or slip downwards, its brilliantly designed and sits on a little ledge to prevent that. I did however hang microfiber towels on the top of the brush guard in case it leans backwards against the front of the G. Also note....it is kinda heavy when pulling it upwards out of the bumper. Reinstall the bolts in their holes after you remove the brush guard. Pop in your plastic grill inserts and install the bumper plugs.
