2026 G63 - Both headlights fogging up after shutting off at night - anyone else?
Every night after I park and turn it off, I come around and both headlights have condensation inside. Both sides every single time. By morning it's totally gone ,perfectly clear.
Only happens at night. Never seen it during the day. I'm in NYC so it's been cold at night, around 29 degrees lately.
What's weird is I had a 2021 G63 before this and had a condensation problem too, One headlight only, never went away, dealer replaced the whole unit under warranty.
This feels different since it clears on its own. But it's brand new. should I already be at the dealer making noise. Anyone on the W465 (2026) seeing the same thing? I just happen to notice it by accident, but how many of you actually look at the front of your car 10 minutes after you turn it off when the headlights were on?
To answer your question, fogging up is common in most mb models but it is not a complaint for the G, I hope it is not a bad seal but it does not seem excessive to suggest a bad seal.
Was there a big temperature swing that may have caused condensation? I would look closely after the fogginess clears to see if you can spot any physical water drops inside the lens. By the way...LOVE the color! what is it?
https://static.nhtsa.gov/odi/tsbs/20...17496-0001.pdf
https://static.oemdtc.com/NHTSA-PDFs...29062-0001.pdf
https://static.nhtsa.gov/odi/tsbs/20...08323-0001.pdf
I got the Dark Olive Magno (matte), i attached a copy of my build for reference.
