G55 AMG (W463) Discuss the G55 AMG.
G63 AMG FRONT BRAKE ON G350 BLUETEC
Old May 7, 2013 | 11:07 AM
kelvin12382003's Avatar
G350
Hi all
much better stopping power
please see photo
Old May 7, 2013 | 12:56 PM
drew138's Avatar
993 TT
Pics of rest of G please.
Old May 8, 2013 | 09:54 AM
G350
for some weired reason i cant upload the photo!!!
Old May 9, 2013 | 01:52 PM
Chirenj's Avatar
Mercedes G55 AMG
Hey! Looks Great!
Would you know if the brake kit fits onto a 2011 G55, if yes; How much would that cost also more pics would be awesome!
Old May 11, 2013 | 04:09 PM
revellix's Avatar
CLS 350
Hey Chirenj.
As far as I know the brake system fits on every G-Class, since this car never entirely changes. I found some prices here, I dont know if it is expensive or not. Nevertheless it looks like the brake system of kelvin. You could contact them, if the system fits.
http://www.mercteil.com/en/products/amg-bremsanlage
Old May 16, 2013 | 06:03 AM
Chirenj's Avatar
Mercedes G55 AMG
Thanks i will have a look at that
Old May 22, 2013 | 11:38 AM
G350
just ordered the rear brake. hopefully they would fit!
Old May 22, 2013 | 11:52 AM
revellix's Avatar
CLS 350
Nice,
where did you order them?
Old May 25, 2013 | 01:49 AM
Ted Baldwin's Avatar
300ce
Originally Posted by kelvin12382003
Hi all
please see photo
..... The calipers are made by BREMBO. They are the same calipers used in GL63 and ML63. The calipers themselves do not fit directly on the G-class. They require a set of brackets. Where did you get this bracket? Thanks.
Ted
Old May 25, 2013 | 01:57 AM
G350
Ted
I have the shop custom made for me!
Now waiting for the rear brake arrive
Old May 25, 2013 | 04:28 AM
Amnaggar's Avatar
2010 G55, 2010 C250, Volvo S40 T5, Pajero, Passat, 1995 SL500
Go Brabus. They know their stuff. I wouldn't get creative with breaks!!
Old May 25, 2013 | 06:59 AM
300ce
.......every after market big break kit uses a bracket to attach the calipers to the car, including the shiny AMG breaks and brabus brakes. It's not wimpy piece. It is what bolts the caliper to the outer hub of the car.the part numbers for the red G63 calipers are A1664214098 for the right side and A1664214298 for the left side. These calipers already come with the removable brackets attached to the caliper. But the holes to attach the brackets to the outer hub of the car do not line up. So it is either those are the wrong brackets or Mercedes re-engineered the outer hub of the car which although possible is not likely
......I think the op is mistaken, the bracket is a hefty piece. It is not ordinarily something a brake shop will create. Big break kits are usually sold with the correct brackets to fit the caliper to the care. Here is an example, here is a brabus big brake caliper. The silver looking piece is the removable bracket
http://item.mobileweb.ebay.com/viewi...d=300784589906
Ted
Old May 25, 2013 | 09:19 AM
pagepro's Avatar
Hi all
please see photo
Hi Kelvin, where did you get your calipers from? Is yours a ML/GL 63 part number and modified for your G or is it a G63 part?
I am thinking of buying this caliper too.
Ted
Hi Ted, did you already purchase the caliper and found out it could not fit?
Old May 25, 2013 | 09:57 AM
G350
Kelvin
I brought it from a mercteil. I don't know if it is g63 part number. I don't think it's a problem cos they are the same I think. But my disc is g63 part number for sure. I am waiting for the rear to arrive also the g63 front brake is positioned differenly comparing to our g .
Old May 25, 2013 | 10:13 AM
300ce
......yes. I have it in my hand right now. Tried installing it yesterday. It did not fit. So it will be nice to know the details of what Kevin did, if he can provide it. Thanks
Ted
Old May 25, 2013 | 11:47 AM
pagepro's Avatar
.......the part numbers for the red G63 calipers are A1664214098 for the right side and A1664214298 for the left side. ]
Ted
The part number for the above is for G63/G65? Or did you order using ML63? Because your part number starts with 166, which means its an ML part number. Could that be the reason why the the brackets do not fit because its a ML63 bracket? I found the calipers for part no. xxx908, but xxx298 part number does not exist.
Old May 25, 2013 | 11:56 AM
revellix's Avatar
CLS 350
Ted
I am sure they do not fit without modification.
I know many people use (Carbon Ceramic) SLS AMG Brake Kits for the new G-Class with few modifications. I have to ask which modifications those exactly were, but it works. So maybe you have to modify!
Old May 25, 2013 | 12:06 PM
pagepro's Avatar
I am planning to get it from Mercteil too. What brackets did you have to custom make? It was not a direct fit for you?
Old May 25, 2013 | 02:37 PM
300ce
.......it is the correct part number. I know what you mean. I ordered it with a G63 vin. At the dealer, tit cross references to the 166 part number. The calipers then come stock, with the ML63 brackets. All that is needed is to swap to the correct G63 brackets, but no one has a part number for it separately.
Ted
Old May 25, 2013 | 07:34 PM
G350
no, its not a direct fit. it need to have a bracket, in order to fit onto the car.
The shop cost me 900USD for the whole process(installing and bracket)
Old May 25, 2013 | 08:09 PM
300ce
.......is it possible to find out from the shop who did your car how we can get this bracket? That will be highly appreciated. If you have a contact person and email, we can email the person. Thanks
Ted
Old May 25, 2013 | 08:46 PM
G350
Ted
Hi
i can give you the number, but i dont think the person speaks english. do you want me to ask how much to get the bracket?
Old May 25, 2013 | 11:04 PM
300ce
Hi
....sent you a pm
Old May 26, 2013 | 12:44 AM
pagepro's Avatar
Hi
If you dont mind, please get the price of the bracket. I want to purchase it too.
Old May 26, 2013 | 12:47 AM
pagepro's Avatar
Ted
I found the G63 part number, its A463 421 1198 and a463 421 1298 for the right and left calipers respectively. Why don't you check it with the dealer and ask them to compare if there any description difference between the G and ML part numbers. Maybe it will give us a clue why the brackets do not fit.
