Renntech vs Kleemann
2019 G63 AMG
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Which company does this better? Planning to add one or the other on my G63 soon.
Kleemann promises 690hp and 950nm ( can this be true? )
http://www.kleemann.dk/Performance/Engines/63AMGBT_M157
Renntech promises 635hp and 620nm
http://www.renntechmercedes.de/www/node/1049
So which one is the better? I have never tried anything like this before and would like best results. Renntech also seems a bit more expensive for less the performance. ( I see some other threads where Renntech previously had higher prower, but lessened that apparently?)
'22 Alpina B7,'21 G63 Renntech obviously (wife), Wrangler(kids)
Thanks![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Went through 2 sets (both cracked at less then 10k miles) before giving up and installing original set back again.
Had also problems with Kleemann LSD in my 2006 SL65.
Since then I decided to stick with Renntech,pricier maybe but more reliable and their numbers are real not wishful thinking as from other tuners.
2019 G63 AMG
Thanks. Im only doing the ECU tune, but maybe one thing leads to the other ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I have a bit trouble finding a Renntech dealer. 850km to the closest in germany, else UK. Im located in Denmark. Is it possible to remove ECU by yourself and send it for modification?
Also will ECU mod break warranty? And will MB be able to notice, upon service or other?
It's very hard to beat Kleemann after sales support. Top notch. For that alone I will keep going back to Kleemann. They stand behind their products.
As for removing ECU, you can do it yourself and send it in for tuning. I believe it does void the warranty unfortunately.
There is a member here with the Renntech tune who had great things to say about it. Although I believe they recently backed down their tune to a lower HP figure. Haven't investigated that one but if you speak to them it might be worth asking what / why they did change the reported values. Either they backed off the spec of the tune or were over-reporting the original estimates. Curious as to the true issue / situation.
2013 G63
2013 G63
I spoke with James at Renntech. He said they did dial back the tune but still have the former programming available for purchase. He cited the reason for the adjustment to the concern of too much power for the transmission to handle, when thrusting from a standstill. I tend to use my added gains when on the highway trying to scoot from 60mph to 90 if necessary, when passing priuses and other hybrids that like to go 50-60 mph in the "passing lane."
