General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Lug Bolt problem
Old Sep 24, 2007 | 06:07 PM
forkliftman's Avatar
Lug Bolt problem
Changed tire on '94 E420 and 3 of the 5 lug bolts came off while driving, any ideas what happened. Now I'm having a hard time finding replacements, any ideas on a source?
Old Sep 25, 2007 | 10:00 PM
mleskovar's Avatar
'17 Jaguar XF
Did you mount your spare tire? Is the spare a steel rim and are your four other rims alloy? 3 out of 5 gone....that must have been spooky to discover! Where are you located...no dealers around you?
Old Sep 26, 2007 | 11:50 AM
whoover's Avatar
'19 E63S sedan
Did you torque them? They take 110 ft-lbs.
Old Sep 26, 2007 | 12:05 PM
lkchris's Avatar
'10 CL550, '12 GL550
Sure that's not 80 ft-pounds (equals 110 nm)?
That's what the owners manual says in any event.
Old Sep 26, 2007 | 12:07 PM
lkchris's Avatar
IF you do indeed mount your STEEL spare wheel, you CANNOT use the same lug bolts you use with the alloy wheels.
Somewhere in your tool kit are 5 shorter lug bolts to be used with the steel spare wheel. This is covered in your owners manual and there could be a warning sticker on your spare wheel containing similar instructions.
No trouble at all to go to dealer for new lug bolts.
Old Sep 26, 2007 | 04:29 PM
whoover's Avatar
'19 E63S sedan
It's best to check your manual, but the last seven MBs I've owned have called for 110 ft-lbs/150 Nm.
Old Sep 26, 2007 | 07:15 PM
lkchris's Avatar
The only MB I've ever owned that called for 150 nm is the GL.
The W123, W124, and W210 all required 110 nm (80 ft lb).
The W211 requires 130 nm (96 ft lb).
Never had an S-class, which must be what you've had.
Old Sep 26, 2007 | 07:25 PM
whoover's Avatar
'19 E63S sedan
Yep, different models seem to take different torques. It's always good to check the book. But I still bet the original problem here is that someone forgot to torque at all.
