General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Service A & B, what's the difference
Old Feb 26, 2003 | 03:12 PM
pocholin's Avatar
Volvo V90 CC
What kind of things do they do on each service, what an aprox price for each assuming regular service. Thanks I'm just curious.
Old Feb 28, 2003 | 08:23 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
I got this off a dealer's web site....
and whatever they charge, between 3 to 4 hundred, is too much.
Flexible Service System - A-Service
What we do:
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Flexible Service System - B-Service
What we do:
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
Old Feb 28, 2003 | 09:26 AM
pocholin's Avatar
Volvo V90 CC
Thanks a lot, at least now I know last time I had service B done because they replaced the wiper blade (even though it was fine and wiped fine). If I remember correctly they charged $385.00 for it.
I really don't complain about the cost because it had been 14k miles already, FSS still said 1000 miles before service but I was getting worried about that oil.
Old Feb 28, 2003 | 10:35 AM
Air Marshall Eldritch's Avatar
John Deere
It appears that the A service is essentially an oil/filter change.
All those 'check' items are meaningless.
Old Feb 28, 2003 | 11:17 AM
pocholin's Avatar
Volvo V90 CC
65 dlls oil change at Jiffy lube does the same (I think they check 24 points on your car and lube the joints too), I said 65 because they have to use 8 quarts of syntetic oil, on a regular car w/regular oil I think it is like 25 dlls
Old Mar 1, 2003 | 03:05 AM
SiLvaC32's Avatar
C32
how much is the service A ??? if its only the oil change... i don't want to pay more than 100 bux...
Jerry
Old Mar 1, 2003 | 10:08 AM
pocholin's Avatar
Volvo V90 CC
Jerry
You don't have to pay for it, you have a C32, services are free until 50k miles
Old Mar 1, 2003 | 03:20 PM
SiLvaC32's Avatar
C32
oh yea!! goooooD!
Jerry
Old Mar 1, 2003 | 03:39 PM
pocholin's Avatar
Volvo V90 CC
oh yea!! goooooD!
Jerry
You still might want to check prices for after the 50k miles
Old Mar 3, 2003 | 09:13 AM
taylor192
Guest
Posts: n/a
Re: I got this off a dealer's web site....
What we do:
What we do:
and just like any place, they rediculous amounts they'll charge to top up the fluids, I'd rather just have the oil/filter changes done and that's it.
Has anyone had experience with Service A or B and specifying things they did not want done but were done anyways? I'm not paying $20 for someone to pour a litre of washer fluid in my car, or top up the engine coolant, at least at places like Jiffy Lude they'll ask first before doing it.
Old Mar 3, 2003 | 10:06 AM
John Deere
Jerry
HAHAHAHAHHAHAHAHAHAHHAHAHAHAHHAHAHAHAHAHAAHAHAHAHA HAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAHA HAHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
hundred bucks! hahahahahahahahahahhaha!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
You're killing me!!!!!
No, seriously....a basic oil change runs $175 at my dealer.
The B service runs over $400, and the A service is a bit less than that.
After 50k miles of course.
