General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
SL 63 E S 2024 weight ???
Old Dec 12, 2023 | 03:22 AM
benzclub's Avatar
AMG GT
Hello
where i can find weight SL63 E S P?
Old Dec 13, 2023 | 07:01 AM
Vin_16's Avatar
C-Class
Hi,
Hope this helps.
The weight of a specific vehicle model like the Mercedes-Benz SL63 AMG (assuming that's the model you're referring to) can vary based on factors like the model year, optional features, and any modifications made to the car. However, I can provide you with an approximate weight for the standard SL63 AMG model:
The SL63 AMG typically weighs around 4,100 to 4,300 pounds (1,860 to 1,950 kilograms), depending on the specific model year and additional equipment. For the most accurate and precise information regarding the weight of your particular SL63 AMG model, it's recommended to refer to the owner's manual or contact a Mercedes-Benz dealership as they can provide specific details based on your vehicle's VIN (Vehicle Identification Number) or model specifications.
Old Dec 14, 2023 | 09:19 PM
W205C43PFL's Avatar
Originally Posted by Vin_16
Hi,
Hope this helps.
Well, OP is asking for specifically the SL 63 E Performance but that is not official yet. That said, I guess we can use the the C 63 S E Performance weight to subtract the base W206 weight to get the E Performance drivetrain weight to (sort of?) get the minimal weight of the SL 63 E Performance, that said, given the SL 63 E Performance has the V8, instead of the four cylinder, so it will still be way off. What is the weight of the SL 63's V8 again?
Old Dec 14, 2023 | 09:24 PM
superswiss's Avatar
2019 C63CS
The E Performance system adds about 500 lbs. That's been published by AMG a while back. This includes the battery, EDU, cabling etc. The SL 63 SE has effectively the same powertrain as the GT63 SE and you can see the numbers there. The GT63S weighs around 4700 lbs and the GT63SE comes in at around 5300 lbs.
Old Dec 14, 2023 | 09:25 PM
W205C43PFL's Avatar
The E Performance system adds about 500 lbs. That's been published by AMG a while back. This includes the battery, EDU, cabling etc. The SL 63 SE has effectively the same powertrain as the GT63 SE and you can see the numbers there. The GT63S weighs around 4700 lbs and the GT63SE comes in at around 5200 lbs.
Thanks man, that is probably it, wonder what kind of weight savings did AMG perform on the SL 63 E Performance (if any).
Old Dec 14, 2023 | 10:00 PM
superswiss's Avatar
2019 C63CS
None. AMG has not put any effort into saving weight in other areas for the E Performance models. These are fat pigs and they drive like it. As I mentioned before, I drove the GT63S and GT63SE back to back at the Nürburgring last year. All you feel is the massive weight gain over the regular car. It eats up the performance, considering that the full 800 hp or something are only available for 10 seconds. It ended up being slower on the track, because of the massive weight gain I couldn't drive it as fast w/o flying off the track.
Old Dec 14, 2023 | 10:16 PM
W205C43PFL's Avatar
I must have missed it but I guess nothing was done for the S 63 E Performance as well then.
Old Dec 15, 2023 | 01:39 AM
superswiss's Avatar
2019 C63CS
Not at 5500 lbs, no.
Old Jan 4, 2024 | 09:29 PM
ever7383's Avatar
MB
Old Jan 11, 2024 | 08:24 AM
W205C43PFL's Avatar
I see.
