Vance, we have another problem!
The dealership was not very optimistic during my conversation today. I may need to start looking at a backup plan. Wait many months for another CDI that is not going work, go for a 450 or look at a different vehicle. I have a very numbing feeling right. I can't believe I'm going through this. I really like this truck, alot!
Who knows the reason - there are a lot of possibilities. Maybe the hose supplier used a new type of lubricant in their process and it's just too slick now. Maybe the hose mfg's polymer supplier mixed a bad batch.
On a different tact, what are the chances (have they checked this) that the hose is ok, but the pressure is way off the charts? Maybe due to a blockage/restriction on one end of excessive input pressure on the other?
Either way, it sucks. :thumbdown:
Go get em Jack...get your truck back!
I'm at a loss to understand how something like this could have made it into production.
Steve
Nothing new other than there is something wrong with a pressure building or leaking in the 'bypass' (I was on the cell phone and didn't get the entire story). I don't understand these turbos so I'm not very good describing the situation. Going to the dealership on Monday to find out.
Perhaps you have a defect in the opening portion of the wg system OR you have high pressure on the off side of the wg that prevents it's opening correctly (such as an exhaust system restriction.) The end result in either case would be the turbo spinning too much, developing too much boost (psi), and then blowing your hose off. Actually, the hose blowing off is much better than not, as running too much boost can be disaster for your engine!
For more general info on turbos, check here*: How Turbos Work
*I'm not a mechanic or engineer, but have a little knowledge of them.
There is nothing wrong with an alloy block as long as it can endure the high compression ratio.
As I stressed this is not a straight 6 versus V-6 competition and the Bluetec package is very nice too. I was pointing out why I purchased a 2006 CDi instead of a Bluetec. Money was one factor as I got a sweet deal.
All alloys are fine - less weight, high strength. They do need iron sleeves in the cylinders for wear reasons. Imagine those steel piston rings scraping against alloy cylinder walls...not a good mix.
Went by the dealership right after lunch wanting an update from all parties. I was told they were waiting on another hose to arrive and once it was installed it would be tested and I would be notified. This hose is also for the intercooler. While there I was informed that they had towed another GL320CDI to the dealership over the weekend with the same problem. I don't know the status of it other than that.
Moments ago, I was called and informed that the new has arrived, it was installed and appeared to be holding much better. This new hose appeared to be much longer and of different quality than the original. The new hose was sent directly from MB too. They test drove for nearly 20 miles without problems however, they want to drive it more and hope to have it back to me sometime tomorrow. Stay tuned.....
Wonder how many they have produced with this problem and if they are now installing the longer hose on the production line?
Hoping not to read anything more other than positive results from you. :-)
Jesting aside, hang in there AS. Once you drive the GL those C class are no fun.
No go on the return of my GL. Apparently the hose they put on works but is not the final fix for the problem. MB engineering in CA is sending a new and maybe the first of the new final fix directly from Germany to the dealership. I will be lucky to get the truck back on Fri or Monday at this point. They would allow me to take it today but MB suggested that I didn't b/c it couldn't be guaranteed to hold so they are being cautious. I don't blame them as I don't won't to be stuck again. So the wait continues....
Also, I was informed that the Mobile, AL dealership also has a GL320CDI in for the same problem.
