2009 GL320 - First Impressions
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
Well,
Just filled the first tank...had the truck for about 4 weeks now. Overal VERY happy with the purchase.
Some initial observations:
Gas - 22 mpg, mainly highway, 70-80mph - not too bad considering the lead foot!
Pleasant surprises:
Steering really is good, very responsive for a big truck IMO
Ride is superb, if you closed your eyes you couldn't tell if you're in a S-class or a truck
Turning radius is much better than i thought it would be
Dislikes:
TPMS - how does it not have individiual pressure readings for all 4 wheels (i know it does for 2010)
COMAND is slow - only in a benz can you pick a radio station via a preset (satellite), and then wait 2-3 seconds
BACKUP CAMERA - also slow, by the time i start reversing the camera just kicks in
STEERING WHEEL FUNCTION - not being able to choose the source for sound (AM/FM/SAT/etc.) via a button on the steering wheel is a annoyance for a surfer like myself. Most cars allow you to do that.
I'm curious to hear what the rest of the GL crowd thinks...
Aceman
Pleasant surprises:
Dislikes:
Aceman
Well,
Pleasant surprises:
Dislikes:
Aceman
Pleasant surprises:
Dislikes:
Aceman
i'm with you on the tpms. but at least the 2010's have the advance tpms so it shows the individual tire pressures. i wonder if its possible to get the new sensors and update the instrument cluster to show individual pressure.
backup camera, mine turns on quickly... more quickly than my old 2007 ml500.
and i too would like to have the ability to change through radio/sat/ipod/cd/etc.
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
I'm still happy with my 2007 GL320 CDI. If I don't "lead foot" it off the light and wait for the computer to completely set everything up, it accelerates better than just about anything I've driven. The handling is "big Mercedes" all around, which is to say it's a lot more agile than just about any big American car (and IMHO most small ones, too) but it's hardly a Porsche or M3. Turning radius is, I think, about where it should be. Making it smaller would probably require a shorter wheelbase, and that would affect the gorgeous freeway handling.
The COMAND system and radio, especially on the aught-7, are absolute dinosaurs. I don't know what, if anything, to do about that short of completely replacing the head unit, and that would screw up a bunch of things (damned integrated COMAND!) Seating is a teensy bit narrow and the cruise control stalk is way too close to the turn signal. After two years and nearly 70,000 miles, I still whack one when I mean to hit the other. The actual performance of the stereo is on par with what I expect from a factory system - that is to say, good without being outstanding. Some of the "features" of the GL (like the sun roof stopping to back up on auto-close - sometimes!) still mystify me, but it's usually a "discussion" about who's taking the GL when it comes time to do highway driving; the wife, who really loves her 2004 RX330, has a tough time deciding on that versus mine when she's going cross-country (though she does prefer her smaller truck in the city).
I hate having a black car in Arizona. Not because of the heat but because of the amazing visibility of the inevitable spider-webs that come from all the sand out here. But it is a very slick looking truck, with the 18" chrome wheels (DAMNED hard to find tires for that - more later), the polished stainless trim, and the chrome fins. I also think MB have got vinyl right with MB Tex. It fools everyone. And I like the "tan."
Right now, I have four tires with four different levels of wear (thank you Discount Tire for their road hazard, really worth it) but they're not the OEM Michelins. Driving with one that's too worn to properly balance is, well, wrong. Probably dangerous. So I'm going back to the performance tire, which wears quickly, because it rides so much nicer. But finding that size tire in a good brand/model is really tough. It's got to have the right speed and load rating or I say "no," so that cuts a lot of them out. Why not just put nice big 20s on to start with? Probably ride, with the cushier tires (if that's a word), but it's still annoying.
Anyway, you asked, so there it is, pretty much my opinion of the beast.
STP
STP
STP, You've probably already looked into this, but does the backing up of your sunroof have anything to do with the "synchronization" of the motor? My rear windows were doing that too and then I read in the manual that you have to sync the windows if they've been blocked or your battery has died/been disconnected. You just close the window and hold the switch for a second and the problem is solved. Maybe your track caused some resistance and threw your motor out of sync?
Well,
Pleasant surprises:
Dislikes:
Aceman
Pleasant surprises:
Dislikes:
Aceman
I've been on two long road trips (500+ miles in each direction) and that is where the 320 really shines. I agree that it's like driving a sedan and it seems like it makes you a better driver than you actually are because it just wants to go where you point it. The steering isn't too tight and certainly isn't loose. For a big SUV, I couldn't ask for a better engine/chassis/suspension for cruising on the freeway.
The turbo lag takes some getting used to when accelerating from a stop but the sound of the engine and the fuel mileage make up for it. I'm still trying to figure out the best way to accelerate from a stop. When you really gun it, the RPM's go way above the engines ideal power band. I've tried to use the paddles to shift up earlier, but the transmission ignores the input.
I think all of the impressions are spot on. As far as command, what it needs is scroll wheel like on all other newer MB. Also it would've been much better if command screen was higher, but that cannot be changed without redesigning dashboard. Coming from 5 series I really miss high screen and scroll wheel, just too many buttons to get used to. 2010 has a lot more functionality in its computer, I wish there was software update for 2009, I think system is essentially the same.
As far as turbo lag from the stop, what I find is that you have to be a bit more aggressive when you driving off after first starting the engine. The transmission is adaptive and it seems to be more responsive like that; gunning it will not work because of the single turbo setup, you have to be gradual to a degree.
1 Post
STP
2008 GL 320 CDI
It's possible - but it's also kind of random. Like today - I dropped all the windows and opened up the roof because the temp was nice this morning, but as it heated up and I wanted A/C I closed everything and the roof just closed. Possibly it's because I was in motion and it stops if I'm not moving or in park? Just thought of that - I'll have to check!
STP
STP
2008 GL 320 CDI
I agree with all these impressions. My only beef with the truck is the very rough downshifting of the transmission when the engine is cold, which appears just to be a characteristic of the diesel engine/transmission combo. Otherwise, a wonderful vehicle all around.
Well,
As for changing source with steering, it would be nice but i don't think any benz let's you do that, does it? Not the three I have owned.
Our '09 has been great, but I'm still not a fan of the 7-speed automatic for stop & go. It's much tougher to find that perfect pedal position for around-town acceleration, unlike the 5spd auto in our '05 E cdi where the ratios and shift points under various throttle conditions are near-perfect. 7spd works great on the highway, though.
Just drove my cousin's new '10 Jetta TDI with the DSG-auto, and it is an absolutely ideal transmission for a diesel, with immediate shifts at the perfect shift points for desired acceleration.
Other than that, our '09 Bluetec has been driving like a dream. Love all the upgrades and options available on '09 (especially ADS), but wish that ventilated/MC front seats and heated rear seats were available. Definitely prefer the look of the '09 to the '10 model, except for the LED taillights.
If you aren't already, buy your adblue from VW dealerships in 2.5 gallon containers for about $15ea instead of 0.5 gallon containers from MB for $12/ea. You'll need a long-neck funnel to fill the tank since the 2.5 gal containers don't have the spout that fits into the tank.
1 Post
Was the Jetta AdBlue (whatever VW's calling it) or just TDI still? I've been very tempted by VW's diesel offerings because they're sedans. I know MB's got the E (an excellent car), but BMW has brought a 3-series sedan in to the mix and is threatening more, and VW has a nice lineup that includes the Touareg (is that how it's spelled) with the massive V10.
doesn't it make you sick...
2.5 Gallons - $ 60.00 from benz
As if we're not taxed enough, once you buy the car you start paying the mercedes tax
Aceman
The new Jetta TDI is VERY impressive and makes do without any adblue due to the small displacement. The DSG really adds to the experience.
2.5 Gallons - $ 15.00 from VW
1 Post
And how big is the tank? (I know I'll get flamed for this one, it is almost certainly mentioned elsewhere.)
Big enough to not require filling ['normal' driving behavior] between factory recommended oil change intervals. (another 'Oh - by the way' for the dealer to add to your oil change bill)
8.3 US Gal. I've read that they are stocking jugs of generic Adblue known as DEF at truck stops. I'll be checking the price and purity on my next road trip which is about two weeks away. If someone else knows this information, it would be great to hear. I've read that all Travelcenters of America are stocking it.
Stopped at a Travelcenters of America today. They are selling 2.5 gal DEF (generic for Adblue) containers for $9.99. You have to buy it in their truck service shop not the retail store. The containers say that it exceeds ISO 22241.
I'm probably going to run with that tip later. On my 10,000 mile Service A, the dealership quoted me $239 "plus supplies." Since I have Prepaid Service, I said OK. Then I got a bill for $135 worth of "supplies." I questioned it and it turned out it was 4.5 gallons of AdBlue at $15 per half gallon. Well, Prepaid Service covers that for the GL320 as well, so after speaking to the Service Advisor I got a revised bill of $0.
All's well that ends well, but it certainly was a reminder: when I get to the first service interval that I have to pay for, I'll be sure to top off the AdBlue tank with the cheap VW version before I go to the dealer.
At $15 per half gallon, it's not meeting the hype it had early on, when Mercedes and others claimed that the refill would cost about the same per gallon as diesel. Diesel is $2.60 right now -- AdBlue is $30.00 at the dealership.
not blown away
GL320 is primarily my wife's vehicle
agree with slow back up camera
my wife took the car in after it failed to start (no explanation) and apparently they upgraded the comand software. the back up camera display now has two vertical and one horizontal lines to guide in reverse.
clearly the mileage is amazing 18 around town 26-27 with cruise control on hwy. i drive a 2003 land cruiser and i'm lucky to get 15 mpg down hill with the wind at my back.
i'm not sold on the reliability of this vehicle, and, since i recommended this vehicle to my wife, i am getting an earful: it failed to start again yesterday. MB roadside assistance started the gl without a problem.
needless to say, i'm driving the car now, and my wife is in the land cruiser.
we'll see how it behaves.
