Steering Mounted Shifters - Can they be Disabled?
2008 GL320 CDI, 1997 528i (ret.), Lex GS350
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Help! Is there a way to disable the steering mounted shifters? They are jsut way too easy to press even when you dont intend to.
You're talking about the steering wheel buttons or paddles.
They are simply switches and clearly can be disconnected.
Whether this creates an error message is unknown to me.
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Disabling the paddle shifters ( if possible ) will mean that there will be no way to tell the transmission to remain in a specific gear! Why would anyone want to disable the capability???
And why would one want to tell the tranny to remain in a specific gear? Especially when, using the paddles, the transmission won't upshift anyway even if you tell it to do so! And it certainly won't remain in that higher gear if it doesn't want to, even if you tell it to.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
- Mark
GL550
Try traveling a one lane dirt/mud/snow ( unplowed ) road in the hills of Vermont and the ability to tell the trans to not go beyond 2nd is pretty helpful. Likewise, if you are towing....... there are times when holding in a lower gear will help with long downhill braking. So its not so much the ability to UPSHIFT for me....... it's the other way around..... and I would not have a vehicle that doesn't allow for that.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
09 GL550, 08 S550 4MATIC w/sport package
[QUOTE=blittle;4590105]Try traveling a one lane dirt/mud/snow ( unplowed ) road in the hills of Vermont and the ability to tell the trans to not go beyond 2nd is pretty helpful. Likewise, if you are towing....... there are times when holding in a lower gear will help with long downhill braking. So its not so much the ability to UPSHIFT for me....... it's the other way around..... and I would not have a vehicle that doesn't allow for that.
[/QUOTE
I'll second that, you can almost virtually come to a stop without using your brakes on a snow covered hill. Having a 550 with snow boards for tires, that is an invaluable asset.
