Rear plastic roof panel
If anyone finds a way to smooth it out, i'd be interested to know how (other than replacing it).
I’m going to take a bunch of photos to help everyone figure it out.
I’ve had wrangler all of my life, and my last was an 04’. My neighbor has a 2017 wrangler, and did a complete flush on every fluid and changed out his plugs. This was a Mercedes design…. I literally had to remove the top of the motor to just change the plugs, and they have parts breaking because they used plastic instead of metal. I have to help him rip out something to do with the oil cooler. Thanks Mercedes!
This is all of the rubber seal they installed to protect water from getting inside. It’s horrible!!!!
There’s the holes headed down through the body. So that’s cheap little piece of rubber is suppose to stop the water. Nope…
I put more, but I put black silicone adhesive around each opening PLUS around the bottom of the rail going back in.
For further protection and make sure the world will end before it leaks again I also put silicone on the back of the nut. I’m going to make sure this SOB floats when I get done.
You can see how they SHOULD have done it. They SHOULD have at least placed rubber washers on the underneath.
thanks Martin.
thanks Martin.
