Running board DIY
Old May 4, 2012 | 03:21 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Running board DIY
Order a set of OEM style running board from ebay. DIY install.
took about 4 hours.
1. remove the lock pins form tire well, pry the center lock pin out then remove the rest. there are 3 at front and 2 at rear.
2, remove the jack pad with larger screw driver.
3. remove 10mm plastic fastener under body. there is about 8 or them didnt count . couldnt get a good picture.
4. peel the bottom rocker panel away form the stud for the plastic fastener.
starting in the rear first seem to work better.
5. unlock the rocker panel away from body. doors open, Use a flat screw driver to poke and unlock the panel.. flash light will help locate the lock
6. remove the bolts to remove the locking molding.
7. bolt on the metal assemble for the new running board. use supplied new bolts.
My assemble didnt fit like a glove. need some adjustment to get all the studs that is pointing downwards.
horizontal studs were perfect fit.
8. install the supplied lower cover. mine needed a little bit of cutting. attached it with the plastic bolt that came off the rocker panel from disassembly.
9 install the jack pads. I used the old ones they seem to get back on easier and tighter than the new ones.
10. install the plastic / aluminum cover for the running board. there are 7 snap clips that fastens to the black clip slots. some may be difficult to lock on..
11. install the plastic oval screw retainer and screw in the running board cover to the assembly. The retainer and screw act as a clamp to the aluminum structure.
12. install the push lock pin back in the wheel wells.
done. That took about 2 hours now do the other side.
I suppose if can be done faster but there are just a lot of bolts and snaps to deal with carefully. powered tools wont really help actually may not be wise to use for this installation.
Old May 4, 2012 | 05:10 PM
cmarshack's Avatar
GL450; Audi Q7 sline; GX470-SOLD, E55-SOLD, Range Rover Supercharged-Sold
Nicely done!
Anyone know if the little black rubber traction ovals are replaceable? My new (to me) CPO 2010 already lost one.
Old May 5, 2012 | 03:46 AM
MrPrometheus's Avatar
2009 GL450
Where did you purchase the running boards? How is the quality? Just as good as the OEM's?
Old May 5, 2012 | 01:43 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by cmarshack
Nicely done!
They are all attached to one piece that you can separate from the tread plate. I don't know if MB has a separate part number for this particular part.
Old May 23, 2012 | 04:22 PM
RCorney17's Avatar
2007 GL450, 2003 BMW 325i
Nice write up! I need to find this set on e-bay too. I've searched and all I can find is the dorky nerf bars. Our old ML had the OEM step sides and we miss them in our GL now.
Old May 23, 2012 | 06:20 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
You can get it here :
http://mercedespartspeople.com/Searc...Running+Boards
Old Mar 31, 2013 | 08:55 AM
hercules's Avatar
W203 C200K-2003
took about 4 hours.
Can you please let me have a pic of the jack pad fitted, Thanks
I have mine and will be installing it soon
Old Apr 3, 2013 | 01:34 PM
atwal's Avatar
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
This write came in handy yesterday when I installed the factory running boards. They fit very good. I had trouble installing new jack point that came with the running board. I end up installing the old ones. Thanks.
Old Apr 5, 2013 | 01:18 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Nice work.
How much were these running boards?
My GLK ones ran me $500...and I installed myself.
If these are more affordable for the GL owners...then its a great find.
Thanks for sharing.
Pete
Old May 23, 2013 | 10:59 AM
jonathankreb's Avatar
'98 E320 and '08 GL320
Just completed the installation of my running boards last night. The instructions above were a big help--I'm sure they saved me a lot of head scratching. Was able to knock it out in about 3 hrs. A few comments/observations:
1) I scratched me head a little while on the rubber jack pads. The factory running board kit has new pads, and confusingly, they fit inside of the metal box that is part of the bracket at the end of the running board mount. I was thinking that they must go inside, until I found the rubber plugs that are designed to plug the original hole in the body, then I knew that the new pad was supposed to go under the bracket, just similar to the original installation.I didn't have much luck trying to screw the plastic plug into the jack pad, but found that tapping them in with a hammer worked just fine.
2) I bought factory running boards from OE discount parts online. They had the best price I saw anywhere, came to about $850. I saw some aftermarket "OE style" ones on ebay that looked to have an almost identical design for half the price. I wasn't just blown away by the fit and finish of the OEM parts, would be very curious how the after market ones compare.
Old Feb 27, 2017 | 02:43 AM
StradaRedlands's Avatar
'07 GL450
Adding on to this old thread. Aftermarket made in China X164 running boards are being blown out right now on ebay. I bought a set for $150 + $50 shipping. There are multiple sellers, but all are based out of Walnut, CA or Kentucky, so presume it's the same place. The ones I bought were from Kentucky, but shipped from California FWIW.
Fitment is probably 95% of factory kit. A little gap front at each end of them where they wrap around the edge of the body. Don't see a way of getting around that. Might not be the best if you have salted winter roads, as it would be a place for the rust gremlins to take hold.
Thanks to @fkong777 for the directions. Pretty easy install, other than having to take the individual push clips off and install them ahead of time. I didn't know what to do with those extra rubber plugs, now its obvious I need to go back and plug the frame holes from the original jack pads. Hopefully able to do it after the fact!
Old Feb 28, 2017 | 02:51 PM
ddruker's Avatar
2011 GL 350, P1 Package, HID headlamps, Blind spot assist, Parktronic, Wood steering wheel
any commentary on the quality and durability of the chinese knock off running boards? At $200, if the quality is reasonable, I think "why not" - a very different cost/benefit equation than $1,000 for the OEM running boards....
Old Feb 28, 2017 | 04:00 PM
'07 GL450
I think it's a great addition for $200. Took me about four hours to get the job done, but mainly as I couldn't get the clips to slip in and catch. A little learning curve. Or pay a shop $200 to mount them and you're still way ahead.
As to quality, the materials used are very high. Solid plastic, just the right amount of flex. The attachment base you see in my photo above is aluminum, and finished roughly in places, but won't be seen. Fitment is the only negative area. The outer cover fits almost good enough. I'd say it's 3-5mm short on each end, and the fender well trim pieces don't attach up just right. But again, at 1/5 OEM price, I'm not complaining. I think they will age will, and won't look bad with use. My wife loves them and uses them. They also let me access the roof for bike racks, something that was a complete hassle previously.
If you live where there is snow and the roads are salted, I think the gap will let in moisture and slush/slurry that could lead to body rust. But you probably have to deal with that anyway, so maybe not an issue.
tl;dr Right now great prices, I think a good upgrade.
Old Feb 28, 2017 | 04:07 PM
mefferso's Avatar
BMW 335d
Thanks for the feedback. My wife is pregnant and I was thinking of getting some running boards to make it easier for her to get in and out. I think I found the ones you are talking about on ebay for around $200 after shipping. Would you mind snapping a few photos of what they look like installed?
Old Feb 28, 2017 | 10:16 PM
'07 GL450
Sure! I'm 6" and don't benefit from them that much. My wife is 5'9" and she likes them a lot for entering/exiting.
Here's the seller BTW: http://www.ebay.com/usr/eg-motor?_tr...72.m2749.l2754 No connection to them. Just confirming they sent the actual product at a good price!
Dirty truck pics:
Overall fit seen from front on driver's side.
Short gap on leading edge, and fit below door hinge.
Short in the back, and small gap on trailing edge.
Old Mar 1, 2017 | 09:53 AM
mefferso's Avatar
BMW 335d
They look great to me. And for $200, I can certainly live with those minor fitment issues. No one will ever notice that. My wife is only 5'3", so she will definitely get good use out of them. Thanks so much for the pictures and ebay link.
Old Mar 1, 2017 | 11:55 AM
'07 GL450
At that price, you can't go wrong! If you don't like 'em, just put them on CL and re-sell easily!
Old Mar 3, 2017 | 01:54 AM
'07 GL450
FWIW, I plugged the frame holes this evening. Had to remove the end pieces of the assembly to access them, but was pretty easy. Maybe 45 minutes including getting tools and everything. Next time I'll put them in first!!!!
Old Mar 16, 2017 | 11:28 AM
ddruker's Avatar
I bought the chinese knock offs and am installing them as we speak. The guide above is extremely helpful. It's a very quick process, except for the snap clips, which I'm really struggling with.
As far as the install goes, I temporarily loosened the bolts that attach the steel sections that hold the jack points to the main aluminum sections of the running board frame to get everything under the truck to line up perfectly. I did not need to trim anything.
Both of the bottom plastic covers were broken during shipping - one was cracked in half, the other had a chunk cracked out of it. The vendor is sending me replacements. The good news is they can bolt on after the rest of the assembly is installed.
I'm finding it impossible to get the push clips that attach the main covers to the aluminum frame to snap in. What did you guys do to work around this? I can get one or two of them, but I can see the rest of the internal receptacles bending inward, which is causing the remaining clips to not click in. Thoughts?
Old Mar 16, 2017 | 10:19 PM
'07 GL450
I had to sit down with a small screwdriver and pry the clips off of the inserts individually. Very sore fingers by the time I was done! I then re-bent the teeth in a little bit, and snapped them into the metal frame. I then carefully lined up the outer cover, adjusted the clips to line up, and pushed in the tabs to the clips/frame. Otherwise it wouldn't grab at all. What is this two weeks in, and it's holding fine! I still haven't installed the bottom plastic piece. Not sure what purpose it would serve.
I have noticed that the aluminum skin is really thin, and dents easily. I'm sure it won't hold up as well as OEM, but at 1/5 the cost for a 10 year old vehicle, no complaints.
Old Mar 17, 2017 | 03:40 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Is there a good way to clean these boards? Just picked up a GL350 and the boards are kinda dirty and can't clean them off good when washing.
Old Mar 17, 2017 | 08:05 PM
ddruker's Avatar
Strada I used your technique - remove the clips first before trying to install the running board covers.
When I did this on the drivers side, which I hadn't messed around with already - it was very easy - the new running board popped right on. Perhaps an hour total on this side.
I think I must have bent the clips on the passenger side trying to do it the "right way" - it was still pretty much a nightmare but I got it done in the end. Probably spent four hours struggling with it all in all.
Running boards are now installed and look good. Definitely some small funky fit issues here and there, but all in all for $200, I cannot complain...
Old Mar 18, 2017 | 06:20 PM
YodaSyrup's Avatar
X164 GL550, F10 535 6MT
Barkeepers Friend - put some on, let it sit for a couple of minutes and then hit it with a nylon brush and a toothbrush.
Old Mar 19, 2017 | 02:06 PM
Jason B's Avatar
Good to know. What about a few missing black rubber circles on the running boards? Is there a way to get just a few?
Old Mar 19, 2017 | 02:32 PM
YodaSyrup's Avatar
I don't think so. My understanding is that there are a couple per side that are screw covers and might be replaceable, but the rest are part of a one piece membrane that spans the entire length and is sandwiched between the other parts. Can anyone else who has fixed this confirm?
