Tire pressure message
Old Dec 4, 2012 | 12:55 PM
RCorney17's Avatar
2007 GL450, 2003 BMW 325i
Periodically I get the "check tire pressure" message in the instrument cluster. I've checked the tire pressure with my digital pressure gauge (not in mountains but more or less sea level) and they all register the same. I've gone through the computer to check the pressure and found that they are all the same.
Is this a sensor going bad? Something else? Battery related?
Thanks for the help.
Old Dec 5, 2012 | 07:23 AM
MRAMG1's Avatar
S600, GL450, GLC 43
If all the tires are above 30psi, it is more than likely that one or more of your batteries in the sensors are going bad. Luckily, you can buy new sensors from tirerack, as the idiots at MB made the oem sensors with a NON replaceable battery. Go figure?
Old Dec 5, 2012 | 08:33 AM
alx's Avatar
alx
All your tires need to be at 30 psi or over at all times.
With the colder weather, this is not always the case.
Old May 6, 2013 | 09:25 PM
tahir's Avatar
2007 GL 450
i have the same msg.. i want to replace censors too...by sensors do you guys mean the TPMS?
Old May 8, 2013 | 11:53 PM
aggst1's Avatar
2011 GL450, '06 R500 traded, '08 ML350 sold
No need to replace TPMS sensors. You just need to reset the TPMS system. If I'm not mistaking, you do that from one of the menus on the center screen. Once the sensors are tripped they need reset. Check the manual
Old May 15, 2013 | 12:35 PM
honda90's Avatar
2006 Purple Mini cooper S conv, RRS 2008 gone, 2011 GL350 Palladium Silver!!!
My Gl350 came with runflats, and my winter tires are not. Is there anything that has to happen to let the computer know about the different tires I'm using?
Old May 15, 2013 | 01:37 PM
aggst1's Avatar
No. The car does not "know" what type of tires you have, run flats or not. If you are referring to tire pressure, if you install the TPMS sensors on each you will be fine. If not then you simply will not have any tire pressure info on the front display.
Old May 15, 2013 | 11:34 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Just had that message on my 2008.
It was right after I got home from towing (tires were at 40 rear 38 front)
It was as soon as I disconnected the trailer.
I figured it was a reminder to bring the tires back to normal range.
Or maybe one sensor is going bad.
I will watch it a while and hope I don't need new sensors till I need new tires.
Old May 16, 2013 | 01:10 AM
honda90's Avatar
What I find bizzare is that we have paid dearly for this vehicle and yet the lady down the road driving her toyota highlander knows exactly what tire pressure is in each tire....we don't know anything!!!!! Not fair
Old May 16, 2013 | 12:17 PM
LEOSOPHIE's Avatar
GL550
And it is still a Toyota!
Old May 16, 2013 | 12:45 PM
aggst1's Avatar
Not following your frustration. Doesn't your car tell you EXACTLY what tire pressure each tire has? At all times?
Old May 16, 2013 | 12:51 PM
honda90's Avatar
No it doesn't, up comes a notice on the screen saying ck tire pressure. Doesn't tell which one or by how much. does your's???
Old May 16, 2013 | 02:05 PM
aggst1's Avatar
No it doesn't in the message but all you have to do is go to the menu and see the tire pressures on all four corners. If one or more corners registers less then you know. Also you would check all four tires at the service station anyway wouldn't you?
Old May 16, 2013 | 02:32 PM
honda90's Avatar
Yes, I would and I guess I've never had to deal with low tire pressure, but how cool to have that info as part of the knowledge of the system info on an ongoing basis. Still, don't want to drive a toyota!!
