rear air vent removal/replacement
I would be interested in the info about taking out the seat and removing the duct work as it looks like it’s the only way to get the marble out.
So now there are two GLs in Calgary with the same problem
2) Use a thin, strong lever or screwdriver to push *DOWN* the plastic clip on top of the ashtray. The insertion location of the lever should be between the vinyl and the metallic frame of the top of the ashtray. There is wavy metal above the ashtray and you need to insert above the frame containing the wavy metal. I first tried to push between the fixed wavy metal and the moving part of the ashtray, but that is the wrong location; there is a metal lip above that which meets the vinyl of the console where you insert the lever. The clip faces up and you want to push it down so that the ashtray assembly can pull away from the surrounding console.
3) There are four T-20? screws that will be revealed within the console cavity where the ashtray assembly was that need to be removed.
4) Lift the bottom of the console towards the rear a little bit and then up towards the roof, exposing the electrical wiring.
5) Disconnect the electrical connector to the cigarette lighter/accessory socket and the electrical connector to the A/C controls (there is a plastic latch on the connector that must be pressed, look closely).
