GL450 Daytime Running Light LED
Old Nov 2, 2014 | 02:36 AM
studioab's Avatar
2011 GL 450
I finally replaced factory "yellowish" bulb with bright LED on my 2011 GL450
Big surprise that computer doesn't freak out, no bad bulb error message.
Old Nov 2, 2014 | 12:58 PM
nachilus's Avatar
09' GL550, 05' S55 (sold), 04' Yukon Denali XL, 05' 745il (sold), 01' 740il (sold)
Look Great, What bulb did you use and where did you get it from?
I am also looking for LED license plates without error, any suggestion?
I have a 09' GL550 and looking to do the same.
Old Nov 2, 2014 | 07:08 PM
studioab's Avatar
2011 GL 450
For DRL i used this
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For Front Marker light
For Front Parking light
look at this chart for your truck
http://www.sylvania.com/en-us/applic...l=3168&make=60
Here is what I found as a replacement for 6418 bulb
http://www.amazon.com/s/ref=nb_sb_ss...ed%2Caps%2C535
Old Nov 2, 2014 | 09:39 PM
nachilus's Avatar
And you have no errors, everyone i got so far has errors.
Old Nov 2, 2014 | 11:13 PM
studioab's Avatar
2011 GL 450
If you bug exactly the same light you will see no errors. I'm still looking for LED fog lights, will keep you posted.
Old Nov 2, 2014 | 11:17 PM
nachilus's Avatar
OK thanks.
Old Nov 9, 2014 | 09:46 PM
dimitristx's Avatar
2010 GL450, 2013 E350
DRL OEM bulbs
OK thanks.
Are our DRL lights H11 halogen bulbs? Also, what's the Watt on them? 55?
Thanks.
Old Jan 11, 2015 | 11:02 PM
CoastsideX164's Avatar
2011 GL 350
How are the LED DRLs holding up, StudioAb?
Today I bought a CPO '11 GL350 w/o lighting package, and I ordered these bulbs plus an MTEC HID kit.
Wonder how the DRLs are working for you, any error codes so far? And do you think they are as bright as the halogen DRLs?
Thanks!
Old Mar 20, 2015 | 04:43 PM
2011 GL 350
My $.02 on these. I ordered them and they were fairly easy to install and the color of the bulbs was terrific. But I ultimately stuck with the original halogens because the halogens, from what I could tell, are brighter. Brightness seems to be a function of the housing and the position of the filament of a halogen bulb inside.
I did do an HID conversion on the low beams (MTEC) and it made a gigantic difference. Best investment I have made in the truck so far.
Also, I put 65w H7 halogens in the high beams and that made a big difference. If I had not done the HID kit, I would have put those in the low beams as well. Bought them here: http://store.candlepower.com/osraulhiouh7.html
Old Mar 21, 2015 | 02:11 AM
studioab's Avatar
2011 GL 450
Man, this looks great. thanks for posting.
Old Apr 18, 2015 | 12:18 PM
BoSage's Avatar
Housing on DRL GL450 2010
I could not remove the bulb easily from the the housing of the DRL. There was a metal plate keeping the bulb in place...didnt want to attempt to force it out. How did you get it out?
Old Apr 18, 2015 | 01:47 PM
dimitristx's Avatar
Had the same issue. I used a small thin flat-head Phillips screwdriver carefully to pry it out. Mostly for leverage so that I didn't yank it out by hand and break the bulb. Once I did on the passenger side where there is more room, it was far easier on the driver side even though it was tighter space.
Old May 4, 2015 | 04:06 PM
2011 GL 350
Yeah, I did the same thing. Had to carefully pry with screwdriver. Was not how I wanted to do it but couldn't see any other way. Let us know how it goes, and if you are happy with the light output.
Old Sep 1, 2019 | 10:35 PM
niallboyle23's Avatar
Gl450 2010
How to replace gl450 drl
Ho does anyone know how to remove the existing drl bulb on 2010 gl450
