Mercedes GL450 - wipers, SRS, cigarette lighter and glove box light stopped working
1. The wiper switch brings rear wiper icon on the instrument cluster while I engage it. It seems like the combo switch is still working.
2. I checked wiper on/off and 1/2 relays and they seems to be working properly. However, the wiper on/off relay does not click while it is in the fuse box. It works well outside fuse box when I feed it even with 9v battery.
3. I checked the voltage on the lines to the wiper on/off relay and found out that lines 85 - 86 get 4.5-5.2v only. However the line 30 and 87 get 12.
3. I connected directly 30 and 87 and wipers started to work.
4. I checked the front SAM on all actuations available and all of them work solid, except wipers.
5. Removed тhе front fuse box and checked all of thе connections. All of them аrе in a great state.
Now, I am lost and not sure what is causing the issue. I still cannot solve the problem. Wipers do not work. The only finding is that one of the lines is getting 5v instead 12v. I also do not see the relationship between SRS, cigarette lighter and glove box light.
I am wondering if anyone had the same issue and were able to solve it. Any advice is highly appreciated. Thank you!
But... Check the fuses again : http://www.mercedesmedic.com/gl-fuse-chart-x164/
I will check all fuses again. I did check the fuses before and all looked fine.
I wanted to ask about front SAM. I used Star Diagnostic tool to perform all available to SAM actuations including wipers. The instructions say to turn off wipers combo switch and turn on Terminal 15R (ignition position to on). Then, I used computer to start/access wipers. When I click F3 (Wipers On/Off relay), then no click sound from the relay, but switch graphic in the program goes to position ON. When I used F4 (wipers 1/2 relay), then I hear the click sound from the relay. I am trying to figure out if front SAM can be a problem. My logic is that I can use SAM to switch relays, SAM sends commands to do it. The relay on/off does not respond. The other functions available to SAM are working perfectly. As a result, I ruled out SAM as a failure. DAS provides a list of possible problem where SAM never in the list. The only suggestion is to check On/Off relay and lines from SAM to X25/2 component and from X25/2 to the front fuse box. I;d like to hear your opinion about front SAM. Based on all info provided, would you also make conclusion that SAM is not a problem or not? I tend to believe that maybe relay is a problem but I checked it outside the the fuse box and it seems like it is working correctly. I also replaced my relay with another relay but results the same.
I may need to get new SAM but wondering if I may be able to recover it by reprogramming it as fresh new unit using star diagnostic. My idea is that it is still may be a good hardware piece but something happened on firmware level. Do you have any opinion on that? Thank you in advance!
Don't remember, but I believe your front sam also needs scn coding if replaced.
I went through the standard diagnostic procedures using Xentry/DAS. At the end, the only pointer from DAS was is to replace the faulty front SAM. However, I accidentally found out that if someone will occupy the front passenger seat, then everything like a magic will go back to normal and work as usual including the front and rear wipers, SRS error gone, cigarette lighter and glove box light. I checked it again without a passenger seat to be occupied and everything stopped working. Then, I pushed hard the seat bottom cover few times and everything started to work. My conclusion is that SAM is not in faulty and the SRS/weight sensor has a faulty. I am going to check all of the connections there and replace the sensor mat if necessary.
Unfortunately, the sophisticated diagnostic tool as Xentry did not help here at all. In addition, I have trouble understanding how faulty SRS sensor mat affects the work of front/rear wipers. To me, it is a bad design or some sort of mystery. I hope it helps.
Everything worked great for a couple of days and then it stopped working again. The first suspect was the seat sensors. Seat buckle seems to be working. At least, I don't see any unexpected errors on the dashboard. I removed the passenger seat out of the car and checked/cleaned everything there and was not able to find anything suspicious. Finally, I tested the weight system via STAR/DAS. All sensors communicate with STAR/DAS and provide the correct weight values. No issues reported. Now, I am sort of lost with this German engineered mystery. Initially, I thought the front SAM module is the problem but then all worked fine for few days. Das does not see any issues with SRS at all. I just don't know what is the failure. Still looking for a clue. Thank you in advance.
Yes, I agree it should be some contact issue. I hope that my front SAM did not play a bad joke on me and did work just intermittently exactly at the time I had a passenger on the front seat. I sort of ruled out front SAM. Unfortunately, this issue is very difficult to trace.
I took the passenger seat apart and cleaned the weight sensors as well as checked all of the wire contacts. No results. The weight sensors worked perfectly anyway. I don't see any harnesses below the seat other than to the seat. I will keep looking.
Ironically, the relay was working intermittently. As a result, I did much more work that I should be. I checked this part as the first step. During that time it worked. I hope it will save you a time and money.
