Good deal on replacement GL Battery at Pep Boys
For the main battery, I ended up going with the Bosch Platinum Group 49/H8/L5 AGM. Like that it has a 4 year warranty. Got it at Pep Boys - they are currently running a special for 20% off, plus another $10 mail in rebate - with next day in store pickup. Total cost after tax and bogus "core charge" is about $190 here in California.
I bought a relatively cheap auxiliary battery on-line from Interstate batteries. 12V 1.3AH AGM - Part #SLA105. Total $22 including shipping.
Below is a link for the main batter. Enter code PEPBATT20 at checkout for 20% off... Go back later and download the $10 rebate coupon and mail in.
https://www.pepboys.com/product/deta...203.0L%2520Dsl
Plan to install both this weekend...
Took about an hour to install both the new main and auxiliary batteries this afternoon. Very straightforward following one of the videos of the process posted on youtube. Hardest part was figuring out how to get the old auxiliary battery out - i just could not figure out how to open up or remove the cage that holds it in place. I hooked up a battery tender under the hood while I was replacing the batteries and as such didn't have to reset any computers or other settings once I was done.
Still seems very strange the vaunted Mercedes engineers decided to set this up so you have to slice up your carpet to get the old battery out.
All in all not a very difficult project - but still 10X harder than replacing batteries that are in normal locations in the engine bay or trunk.
Extra tip: If you're also replacing the auxiliary battery, the factory installed auxiliary battery has the terminals on the inside of the docking cage. It's tough to get in there and get the leads off and even tougher to press the connection tabs on the battery down far enough to get them under the top of the cage (meaning they get caught and you can't pull it out). After about 20 minutes of effort to push them down (hand and tools) I ended up muscling the battery out which catches the tabs on the cage and pushes them back the other way. It closes the loop and sparks a tiny bit, but I got it out and reconnected the leads on the new battery with the tabs facing out toward the battery bay via a tip from a tech on another blog post. Worked fine and the wires stayed clear of the big battery.
The entire project probably took me 1:20 and 20-30 were spent wrestling the auxiliary battery. I went slow as it was the first time I've done this and it paid off. Saved a bunch of cash and learned a thing or two. I'd say if you're even somewhat handy that once you get in there it's easy to moderately difficult and just takes some patience. REMEMBER: Always disconnect the negative terminal first when pulling the battery out and reconnect the positive terminal first when putting the new battery in. No idea why, just following instructions I saw 5-6 times while researching.
What happens if the aux battery starts to fail as long as the main battery is good?
Edit: OK, found it in another forum. See Post 24
https://mbworld.org/forums/gl-class-...ry-issues.html
However, looks tough to change without also pulling out the main battery.
Guess I'm gonna take my chances and hope it lasts another 2-3 years until I need another new main battery.
