GL 350 Bluetec with error codes P111500 and P111600
I had error codes prior to this engine oil change and they are P111500 and P111600. Can anybody help about the meaning of these codes and the problems I am going through and are these codes connected?
If I need to fix this code what will be rough estimate of costs of repair?
Thank you
And your oil loss is not due to the 0w40 oil as while not -the- oil for the motor it is ok. You have an oil loss problem. Find it.
Regarding the codes- you sure those are the codes? What were they read with?
Oh WAS should not be mistaken wig WAF (wife acceptance factor- an important measurement for all toys a guy has)
I had the codes analysed and had to replace DPF which costed me 3200.
I do not what will be the cost to fix the loss of engine oil?
There is no oil leak anywhere. DO you think iol is being burned in the engine or turbo?
If anyone knows what will be the cost to fix this type of problem I would appreciate this.
1. you are leaking it - it is possible you are losing oil at the oil cooler seals located in the v of the motor. it accumulates there as the seals leak and then when the truck is tilted upward the oil drains on the exhaust burning without a trace.
check the following- after driving for a while stop at an incline and take a whiff in the space between the engine hood and the windshield wipers- you dont have to even open the hood. if it smells like burnt oil- there is a good chance of what i said above to be the problem.
2. if there is no smell - i am suspicious that if the dpf was replaced you are burning the oil - engine is usually never the culprit (piston seals, valve guides are very strong), but the turbo seals might be failing. to lose that much oil the seals need to be in really bad shape and can be inspected by a knowledgeable tech. if that is the case you can get a rebuild turbo and have an indy replace it. the dealer will put a new turbo- very expensive.
mine 09gl320 bluetec has been a money pit/parts pig
400.---strut
600.---adblue heater
125.---wheel bearing
450.---NOx sensor
not to mention oil, air filters, diff fluid, trans fluid change, tires soon, still to do---> antifreeze, brake fluid, fuel filter
my first year of ownership
Few days ago I took my GL to dealership and had compression and leak test performed as advised by other repair shop. The test revealed engine is okay and they replaced turbo seals. I was told by the mechanics that I might have been using an engine oil not suitable for my bluetec engine, hence it is being burnt by the engine. They replaced oil and ask me to drive 1000 miles and come back to see if the problem persists. I am waiting.
