YES or NO, that's the question - Buying with high mileage.
The price is really low, u$s10k, very well maintained and condition, actual owner is a mechanic itself, he did all the maintenance regularly, new air suspension and compressor last year. New transmission fluid, - differential oil, filters, rotors and pads, etc.
The high millage is travelling back and forth from Canada to the States.
I understand repairs on this car are not cheap, but I always try to DIY and find parts online, never dealer.
Suggestions?
Run away or pull the trigger and play russian roulette?
Thanks in advance.
For instance, can you find a source for the rubber suspension bushings the front end of the 350 will soon require? Are you sure your non dealer source has EXACTLY what you will need?
The question is why so cheap. At 160k that truck even an 09 is worth more.
bottom line be ready to get your hands dirty
When I knocked out the radiator, did the hoses too along with the power steering reservoir as it had a minor leak and it was cheap and easy to do with the radiator and fan out of the way.
Overall though for the miles it has held up quite well. Interior and exterior still look like new. Still drives like a dream.
