front end sitting low after changing both front struts
Old Jun 7, 2017 | 11:24 AM
luxcar's Avatar
08 GL550, 08 BMW 550i, 07 MDX
I have a 2008 GL550. The front was making noise and ride was not great so I decided to change both front struts.
I have both front struts replaced 2 days ago with remanufactured struts. Today I noticed that front end is sitting low. Passenger side has about an inch gap but driver side seems very low. Any ideas? Job was done by an indy.
Anything other than a faulty strut?
Old Jun 7, 2017 | 11:37 AM
alx's Avatar
alx
not really. the airmatic should autolevel / recover after shock replacement. if it is not holding height overnight you have a shock or valveblock leak. valveblock leaks are rare.
btw, one bad shock will bring down the whole front or back down. however, the offending one will be yet lower.
Old Jun 7, 2017 | 11:49 AM
gl450x164's Avatar
gl450 530i
Make sure the seated the air lines are seated properly
Old Jun 7, 2017 | 11:50 AM
luxcar's Avatar
When I opened the driver door. Front end came up in few seconds.
Old Jun 7, 2017 | 11:52 AM
gl450x164's Avatar
gl450 530i
You have a leak
Old Jun 7, 2017 | 01:25 PM
luxcar's Avatar
Taking it to the installer. Lets see why he finds out
Old Jun 7, 2017 | 02:30 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
Spray some soapy water where lines enter into top of airshock to check for that.
Old Jun 7, 2017 | 05:37 PM
luxcar's Avatar
Took it to mechanic. He diagnosed the strut bag leaking. New strut on the way.
Old Jun 11, 2017 | 11:12 AM
luxcar's Avatar
Replaced the strut with new one. Not leaking anymore
