EBV ABS ESP Inoperative Diagnosis/Rig test
Old Aug 6, 2018 | 08:25 PM
eric_in_sd's Avatar
2007 GL450
So I searched high and low, and was going nuts trying to complete this "Road Test". This is when you have the STAWP VEHIKUL NAO and ABS light (but not ESP) light illuminated.
Finally, with the help of https://mbworld.org/forums/ml55-amg-...-rig-test.html I managed to get it.
Here's the simple version. Plus, I found a slight adjustment.
1. Vehicle stationary, steering centered, foot off brake, engine running, flat ground, open area about 100' or more across.
2. Press ESP Off; ESP warning light will begin flashing. When it goes solid, proceed.
3. Press brake pedal
4. Shift into D
5. Release brake
6. Begin driving 10-15 mph, steering > 90 deg, < 180 deg. You have to execute about a half turn.
7. When ESP light begins flashing, brake to a stop.
8. Shift to N
9. Release brake
Both ABS and ESP lights should go off. If the ABS light is on, you messed up the test and have to repeat it. If the ESP light but not the ABS light is lit, you have an ESP fault - which is why I fiddled (unsuccessfully) with the SAS in the first place.
Old Jan 3, 2020 | 10:20 AM
Ashoke Roy's Avatar
ML 350 Diesel
I had the same problem after hooking up iCarsoft Professional V2.0 diagnostic tool to my 2010 MB ML 350 diesel. Definitely, I did something wrong in the service section of the tool. I got an instruction like eric_in_sd gave but it was very hard to follow through. Later, I contacted iCarsoft and got almost similar instruction as follows:
1.- Stop car with front wheels in straight position and geared at P. ABS light is ON and ESP light is OFF. Parking brake released.
2.- Actuate the service brake and shift to N. Release service brake and push the ESP button. The ESP triangular light flashed and then lit steadily. Immediately, shift to D. Move straight and turned 1/4 of a circle (left or right) with the steering wheel turned >90°.
3.- Stop by using the service brake while straightening the front wheels. The ESP light flashed and ABS light was still ON. Shift to N, and release the service break. The ABS and ESP lights went off. The "EBV, ABS and ESP unavailable Diagnostics/rig test" message disappeared.
I tried several times in an empty paring lot in the morning. It wasn't done properly. I got frustrated and tried to make it simple and non-technical. So I did following thing and worked:
Find a quiet road (horizontal, no up- or down-hill) with a side-road on your right in 100 feet ahead. Stop the car by the road curve in neutral N position. Press ESP button twice; the triangular light flashes a few times then steady. Move gear to drive D position with braking. Let it move forward then turn right to the road and straighten the wheel along the road. The triangular light start to flash again from steady. While straighten the wheel, brake and move the gear to neutral N position. The triangular light will stop first then ESP light off. Voila.
Old Feb 5, 2021 | 05:06 PM
Clc180's Avatar
Clc180
Do you know the procedure with a manual gearbox? Ive accidently activated this test
Old Apr 22, 2021 | 07:55 AM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
Heads up for others, I ended up having to take it into the dealership.
My ABS light still wouldn't turn off after doing the rig test so many times.
They had to reprogram the ABS to get rid of it in the end, didn't take long.
Old Dec 12, 2021 | 10:06 PM
fast_freddy's Avatar
See signature
4. Shift into D
5. Release brake
8. Shift to N
9. Release brake
Thank you. Was goofing around with my CL63 today and made the mistake of screwing around with the steering angle sensor (my active lumbar went - The massaging seat is kaput at the switch (short - fixing that Tuesday, perhaps its related) thinking the steering was screwed up. Having done it before on my Porsche's/BMW's/Etc. I didn't think it'd be a big deal. Boy I was wrong. I was using the iCarsoft MBII, screwed it up then used this simplification to unscrew it. Thank you!
Old Mar 5, 2025 | 12:10 PM
Depesas's Avatar
Tkanks
Thanks for this simple instructions, helped me in the same situation with my R320cdi
Old Nov 8, 2025 | 03:06 PM
General Shelton's Avatar
W203 and w204
what were the errors codes
Old Dec 14, 2025 | 02:52 PM
W203 and w204
4. Shift into D
5. Release brake
8. Shift to N
9. Release brake
Help me do I have to drive until the error flash back at step 6 and 7
Old Dec 14, 2025 | 02:55 PM
W203 and w204
my triangle light doesn't flash it remain yellow
Old Dec 14, 2025 | 03:13 PM
W203 and w204
Anyone to post a video please am battling to solve this 🙏
Old Dec 14, 2025 | 07:53 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Are you sure you’re stuck in rig test or do you have other stuff going on? How did you end up in that condition?
Old Dec 15, 2025 | 03:36 AM
W203 and w204
Power Steering, ABS, EBD, EPS, Run flat indicator, malfunction at same time
4. Shift into D
5. Release brake
8. Shift to N
9. Release brake
Good day
Kindly help me do i have to drive until the error come back on step 6 and also when do i stop to do 7
Old Dec 31, 2025 | 08:31 AM
Giant's Avatar
W204 C220 cdi 646 engine
ABS
How did you solve it
Old Dec 31, 2025 | 08:33 AM
W203 and w204
It went off alone
Old Mar 30, 2026 | 01:48 PM
Jaybruin44's Avatar
2010 C350
I was stuck in road test active with my c350 (w204).
two key points got me out of it.
if the triangle ESP light is flashing, your road test will never work. It has to be solid.
if you have any trouble codes in your brake module other than “road test active”, you will not get a solid ESP light, and you will not be able to complete the road test.
take vehicle to a safe testing location, level ground.
Use scan tool to clear all brake esp related codes.
IMMEDIATELY start the road test.
this worked for me after about 40 failed attempts.
Old Mar 30, 2026 | 05:10 PM
Max Blast's Avatar
NGL450 w/EORP, S550
I was stuck in road test for like a week in my w221.
see my posts for how to do one.
