2011 gl450 left rear hissing and sags
I had an E series a few years ago and while I was unable to find a leak in the bag, it was the issue.It only seemed to leak under certain conditions, which complicated the troubleshooting. When I ordered the new air bags I was convinced the leak was somewhere else, but the new bags fixed it.
Does the suspension go up when the engine is running and only sag once stopped? If so, my money would be on the bag. The E series bags have a schrader type valve on the inlet, so once filled it should not lose pressure unless there is a leak. I cannot confirm at this point, but I would be really surprised if the GL bags were not the same design.
I would be sure to get it addressed soon though. Many think that if it fills when the engine is running they can delay the repairs - but a small leak will only turn into a larger leak. If it goes out on you while driving (or at a place where you can't do the repairs) you will be forced to have it towed. Also the on-board air compressor is not designed to run constant. If it is continually having to replace air leaking from your system you will burn it out pretty quickly - only adding another expense. Leaks from the lines and distribution blocks are not common, and usually due to physical damage. It is almost always the bag being defective.
Also be aware, you likely will need to replace both sides at the same time to avoid an Airmatic error message.The onboard diagnostics seems to expect these to be paired.
I haven't replaced the air suspension on my GL yet, but on my E series it only took about 30 minutes per side to replace.
Good luck!
Good luck!
Most people on here want to help and help you avoid an even bigger expense; the compressor.
Since you have been driving your car, and you have now been getting the cooling down messages you are at risk of having damaged the compressor; which is more expensive.
Try to replace the bags sooner than later to save that compressor.
the reason most people say change the bags right away is the reason yiure getting the cooling down message.
