GL 420 cdi - Pressure in cooling system
Old Jun 16, 2019 | 07:29 PM
Said Ridan's Avatar
W203 C320 cdi
Hi all.
My cousin has a GL 420 cdi that has high pressure in the cooling system. We went to the dealership, they did CO2 test to see if there is any CO2 in the water. They didn't find any. They finally said it might be a head gasket problem. My cousin changed the right head gasket. But unfortunately he still has the problem. He is about to change the left one. Is there anyone here that had a similar problem or that could point us to potential sources for this problem ?
More info:
When we turn on the car, the pressure stays normal. No particular problem. Even after letting the engine run for 5 minutes. When we use the car for a while, the hoses start to be very hard and if we open the water tank's cap, the pressure make water spill out of the tank.
Please tell us your taughts. We are trying to save his holidays with his kids.
Thanks a lot
Old Jun 16, 2019 | 07:55 PM
alx's Avatar
alx
How do you.know you have high pressure? Spraying out of the tank when engine is hot is normal
Old Jun 17, 2019 | 08:36 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yeah, that's normal when an engine starts to heat up
Old Jun 17, 2019 | 09:50 AM
Said Ridan's Avatar
W203 C320 cdi
It is unusual pressure. The hoses are rock hard after 5 minutes driving.
Anyone here have an idea of what could cause the problem ? It is the same symptom as a head gasket problem, but no CO2 in the water, no smoke, no water in oil.
Old Jun 17, 2019 | 11:45 AM
alx's Avatar
alx
it might or might not be a leak. are you losing coolant? it is a leak in the head gasket.
not loosing coolant? recovery tank cap or thermostat
Old Jun 17, 2019 | 11:56 AM
Said Ridan's Avatar
W203 C320 cdi
He is not loosing coolant and we changed the thermostat. And when the car was at the Mercedes dealership, the guy tried to put an other cap, but the problem was still there.
He changed one of the two head gaskets so far, without success. The second is going to be changed this week. And if the problem is still there, I really don't know what we could try next.
The Mercedes dealership is not really helping.
Old Jun 17, 2019 | 12:49 PM
alx's Avatar
alx
if he is not losing coolant and the pressure doesnt drop very quickly back to normal once the engine is off - you do not have a head gasket leak. replacing the other head gasket will not fix your issue
it is possible you have a clogged radiator or a pinched hose somewhere. diesels run very cool by default (when not pushed hard) so a clogged radiator would not result in higher engine or coolant temps, but a higher pressure is common on the supply side. check the hardness of the radiator on the exit side - if it is soft than you have a clogged radiator. if it is hard like the intake side - check the system for hose kinks
Old Jun 17, 2019 | 08:11 PM
Said Ridan's Avatar
W203 C320 cdi
Thank you alx ! I will check that tomorrow. It would be good if it was the radiator. Any cause would be good now as long as we find it now. I'll post a response tomorrow when we check.
Old Jun 17, 2019 | 09:03 PM
BlownV8's Avatar
Is the return line hard too?
Old Jun 18, 2019 | 09:36 AM
Said Ridan's Avatar
W203 C320 cdi
Unfortunately it is also hard after the radiator, yes. So the investigation continues 😣
Someone told me that a clogged particle filter could result in having to much heat in the cooling system and having the water boiling and getting under pressure. I don't really know how this is possible. Have you guys ever heard of this ?
Old Jun 18, 2019 | 10:09 AM
alx's Avatar
alx
it does not work like that so, no...
what you might have is a collapsed hose on the return side. it might or might not be visible. if all hoses are correct i would look at the water pump. is it the stock one with the stock pulley?
Old Jun 18, 2019 | 03:47 PM
Said Ridan's Avatar
W203 C320 cdi
The hoses I see between the engine and the radiator all seem fine. 🤔
I think it is the stock pump, it looked like a normal pump. Are there different types of water pumps ?
Old Jun 18, 2019 | 07:19 PM
BlownV8's Avatar
If you live in a very hot area, someone may have installed a smaller water pump pulley that spins the pump faster to move coolant through the system faster in hopes of the engine running cooler. One of the side effects could be an over pressurized system.
Old Jun 18, 2019 | 10:47 PM
Said Ridan's Avatar
W203 C320 cdi
Ah, we are in France, I don't think we need the special water pump pulley here, I'll try to see the part number to see if it is the right one.
Old Jun 19, 2019 | 05:54 PM
Said Ridan's Avatar
W203 C320 cdi
Apparently the water pump is the regular one.
We checked all the hoses we could see, they all seem alright. 🤔
Old Jun 26, 2019 | 10:59 AM
Said Ridan's Avatar
W203 C320 cdi
After removing the second head, we see this :
Old Jun 26, 2019 | 12:42 PM
alx's Avatar
alx
there is no way you were not losing coolant through that gap
Old Jun 26, 2019 | 01:13 PM
Said Ridan's Avatar
W203 C320 cdi
True.
I guess the pressure made it difficult to spot, but I couldn't see noticeable difference in water level.
Thanks a lot for your help !
I think the Mercedes dealership where I went is a scammer. A friend warned me about him but I didn't listen. There should have been exhaust gas residue in my water. I should have bought a tester kit and tested it myself.
Old Sep 14, 2019 | 04:26 AM
Nenad Nelle's Avatar
mercedes
Did your engine remove for Dichtung replacement
[QUOTE=alx;7788617]there is no way you were not losing coolant through that gap[/QUOTE did you have engine removed for Dichtung
Old Oct 13, 2020 | 02:51 AM
noel chamboko's Avatar
Scania mechanic
Mechanic scania zimbabwe
Check your compressor ..I'm sure is by passing pressure into the cooling system ..simply block those two. Water pipes by the compressor an start your engine. ...
Old Jun 16, 2022 | 05:05 PM
Pachuli2008's Avatar
E420 CDI
True.
Hi, i have in E420 CDI, same problem, lots of pressure on the water loop, it blew up my radiator.
Question, you resurface the head? The block? Because its a wet sleeve desing is there any problem with the reaurfracing? Thanks
Old Nov 6, 2023 | 07:27 PM
SeanyF's Avatar
W164 ML350 CDI
Hi all.
More info:
Thanks a lot
Hello,
Bit of a thread resurrection here; but when you say your cousin changed the right sode head gasket first, but it was the left side that finally solved the problem… you mean in terms of sitting inside the car looking ahead correct?
The right side is the UK Drivers Side, or US Passenger side correct?
Just double checking t see which side is most likely to be the problematic one so I can do extra tests. I know it’s 50:50 either way.
Old Nov 8, 2023 | 08:58 PM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
Sounds normal.
Replaced the head gasket? What made you think to do that? Milky oil? Oily coolant? Did you run the vehicle with the coolant cap off and look/listen for bubbles in the coolant? Sort of a big task to do a headgasket, just cause you might "think" its a problem.
