No start. No fuel. No power at fuel pump. 2007 GL450
Old Oct 11, 2019 | 09:49 PM
wenter's Avatar
2010 ML350 4Matic, 2013 GL450 4Matic
Hi, all
This morning my 2007 GL450 refused to start. It seems that I have left my radio on and it drained the battery. I have tried to jump-start my car from my other car.
Engine is cranking, but it does not start. I have checked and there is no fuel at fuel rail. I have confirmed that my fuse is good as well as the fuel pump relay. Before leaving for work I have pulled the battery and set it to charge.
After work I have checked all fuses and opened the right fuel pump access door. There is no power at fuel pump terminals when key is turned on. I have confirmed with DAS that the key is recognized and that all authorizations are on.
Any suggestions what my next steps should be?
Old Oct 12, 2019 | 09:08 AM
chassis's Avatar
2017 GLE350 4MATIC
Replace the main and auxiliary batteries.
Old Oct 12, 2019 | 01:14 PM
wenter's Avatar
Car still does not start with both new batteries. There is still no fuel at the fuel rail.
Old Oct 12, 2019 | 02:09 PM
chassis's Avatar
2017 GLE350 4MATIC
Read the codes, or have them read. Best is to use a Xentry/DAS system.
Old Oct 12, 2019 | 02:13 PM
wenter's Avatar
Unfortunately there are no error codes.
Old Oct 12, 2019 | 03:36 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The pumps do die around the 10 to 11 year mark.
Old Oct 12, 2019 | 03:56 PM
wenter's Avatar
I have StAR SDS system to check for errors.
Problem is not with fuel pump itself. There is no 12v on the fuel pump connector when ignition is on.
I am beginning to check fuel pump control module.
Old Oct 12, 2019 | 04:31 PM
BlownV8's Avatar
Do you think the fuel pump caused the control module to fail?
Old Oct 12, 2019 | 07:48 PM
wenter's Avatar
Fuel pump was dead. Replaced with a new one and engine started right away.
I was mistaken. My car was not built with FPCM, just a simple relay system.
