Gears lost Luckily it happened to my wife ....
Old Apr 8, 2020 | 11:20 AM
Jyrmex's Avatar
S211
Hi,
I have a 2009 GL 500. It has only 50 000 miles on clock. Any way, She was driving normally in the city and suddenly she lost gear. She rolled the car to side of the road and called me to check it out. So in the instrument cluster was message that ABS and ETC ( or what ever it name is) are inoperative. When try to shift it goes to park,drive and reverse but nothing happens. You can hear that when shifting something moves but nothing, nothing happens. All liquids are inside the trans and engine. I can get in to star diagnostic system tomorrow so now all quesses are welcome. Thanks.
Br,
Jyrki
Old Apr 8, 2020 | 10:37 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Vehicle speed sensor on the valve body maybe, but that should have given you limp home mode in 1st gear. let us know what you find!
Old Apr 9, 2020 | 05:12 PM
DarthVaderpa's Avatar
X166 GL550
I had the same problem. Replaced all wheel speed sensor and problem solved.
Old Apr 10, 2020 | 04:59 PM
Jyrmex's Avatar
S211
Hi,
Did You change speed sensors to every wheel or some other speed sensor? There is a one speed sensor in gear box and that is one, that dealer must change.
We haven´t solve this problem yet. We got also code as low voltage in secondary battery, so we start with change it.
Br,
Jyrki
Old Apr 10, 2020 | 10:56 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by Jyrmex
Hi,
Br,
Jyrki
the vgs on the gearbox valve sensor - if that is what you stored or current Fault code says. There are some non-dealer workarounds that involve shipping your valve body to a third party for coding. Otherwise you’re stuck with the dealer -$$$$$
Old Apr 14, 2020 | 03:06 PM
Jyrmex's Avatar
S211
Hi,
All codes read and zeroed. No new fault codes but still no gears. Saturday we are going to drop gear boxes oil pan to see inside. Let´s hope that problem will found.
Br
Old Apr 18, 2020 | 01:40 PM
Jyrmex's Avatar
S211
Hi,
Today we dropped the oil pan and we found metal glitters in oil. Oil filter was quite shiny when looked inside. So there must be more damage than just some valve or similar.
Put putted the pan back and now it´s changing garage to one that is specialized to trans. Now it´s good time to make some guesses what will be found . Transmission is in 2008 GL 500 with 50 000 mil in clock.
Br,
Jyrki
Old May 6, 2020 | 01:44 PM
Jyrmex's Avatar
S211
Now the gear box is opened. Oil pump was broken and left hard mark´s to torque converter too. Needs total repair.
Br,
Jyrki
