Code P0299, Wire cut on plug on top of oil pan - what is it?
Old Apr 26, 2021 | 07:51 PM
djhagen's Avatar
2012 GL350 Blue Tec
Looking for help to determine what the wires and plug are pictured below. My serpentine shredded last night, knocked out my turbo and gave me a P0299 Turbo/Super Charger underboost. The plug pictured has one cut wire, wondering if that's the culprit or if I need to keep looking
Old Apr 26, 2021 | 07:54 PM
djhagen's Avatar
2012 GL350 Blue Tec
I should add my car is a 2012 GL350 Blue Tec
Old Apr 30, 2021 | 04:02 PM
djhagen's Avatar
2012 GL350 Blue Tec
bump
Old May 3, 2021 | 09:25 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
Check intercooler hoses, you might have a leak.
Old May 3, 2021 | 11:17 AM
djhagen's Avatar
2012 GL350 Blue Tec
Thanks! I will check today.
Old May 3, 2021 | 08:42 PM
DennisG01's Avatar
'08 GL 320 CDI
Is that an oil level sensor?
Old May 3, 2021 | 09:52 PM
djhagen's Avatar
2012 GL350 Blue Tec
I learned today that it's the oil temperature sensor and part of the main wiring harness for the engine. Don't break this one! $800 for the harness and who knows the cost for removal and install! I'm getting the plug repaired.
Regarding the turbo/supercharger underboost, it's not related. If it wasn't broken by the shredding serpentine, it broke when i was cleaning all the stringy remnants.
Old May 3, 2021 | 10:23 PM
DennisG01's Avatar
'08 GL 320 CDI
I'm still struggling to understand how a shredded belt can affect the turbo. The turbo is all the way at the back of the engine and there's no way, even if a piece of belt flew to the back, that it would harm the turbo. There's also no way that you broke the turbo by cleaning things.
Old May 4, 2021 | 12:18 AM
djhagen's Avatar
2012 GL350 Blue Tec
I'm convinced the shredded, spinning remnants of the serpentine cracked or loosened one of the intercooler hoses, so I'm taking it to a diesel specialist tomorrow. The plug and wires in the picture aren't related to the turbo ... just unlucky.
Old May 4, 2021 | 09:08 AM
DennisG01's Avatar
'08 GL 320 CDI
OK, yes, the hoses I could see. You had mentioned the turbo, specifically - that was what I was getting hung up on trying to correlate. The hoes (pipes) aren't all that hard to figure out if you wanted to give it a shot yourself.
