Not sure where to go
As mentioned above, did Mercedes replace the coil and plugs?
For our knowledge, why was the engine replaced? Just wondered since everyone is always bashing the diesel.
oh, excuse me I also just reread the post… This is an X166 and this is a known problem.
Have you had somebody prove to you that the inside of the misfiring cylinder is irreparably damaged?
never mind. You have an X166 GL, this is the sub forum for the x164 which was made until 2012. What you’re describing is a known problem for that year GL and is likely the reason why your engine was replaced in the first place, and now the error has occurred again on your replacement engine. Pieces of the cylinder wall coating are missing likely.
@admin, can you please help OP go to the x166 forum.
The only recourse you have is IF the problem was misdiagnosed by a MB dealership while the extended warranty was still in effect.
Man, I hate turbos when it comes to reliability and longevity. Turbos are fine for situations when you drive it hard and rebuild it often. They work for longevity only if you over-build the xo@# out of them. Volvo levels of indestructibility. Not that long ago, motors used to be 100k mile items. They built them better, and I am now hoping for 250-300k out of my M273, if I go easy on it and take good care of it. Similar for 2000's Toyota and Honda motors. Now with them bolting turbos on everything, we're back to sub-100k mi motors. Especially considering people think "turbo" means "punch it, early and often!"
First year m272/273 had existential valve timing gear issues…see a trend here?
don’t get first year MB anything.
I am aware of the problem OP is facing in this thread, and it’s an M278 specific problem. The basic architecture of this motor builds on the 273 to include the Alumasil? Cylinder liners. There aren’t any problems noted in 273 engines with cylinder walls flaking off, so reasonable man theory states that the addition of boost has provoked that problem.
ha ha yes we do… But I diligently searched for an engine number that was outside the affected range.
